- Joined
- Apr 21, 2005
- Threads
- 116
- Messages
- 26,111
I have a trailer made from a 72-75 Hilux going by the tail lights. One of the axle seals has started to leak. Besides the seal are they any other gaskets I'm going to need? Will I need to press the bearing off to replace the seal?
I'm also thinking about pulling the ring gear and flipping the diff to make it a high pinion for better clearance off-road. Would this create a problem, is the ring gear needed to mix the oil around and lube the outer wheel bearings? Not worried about the pinion since it will not be spinning.
