highest mileage cruisers out there (original engines)
Quit buying checker alternators......:flipoff2:
HAHA.. No, it's been serviced at a place called Clegg's Auto Care. The guy there says that a lot of LCs have the same problem.
Thanks for the info, I'll be looking into the Wasatch Cruisers.
'97 - 115,000
All original OEM parts. In nine years on the road, she has only gotten oil/filter changes, new shoes, replaced suspension w/ OME 2.5" Heavy, and replaced OEM front bumper w/ Slee's single-hoop.
'93 285,000. Doing the radiator in the next week and other than that just pm.
'97 LX450 250,000. Upper oil pan gasket at 165,000.
Both have had starters and I think alternators, but, it's been so many miles ago I don't remember. Front axle rebuilds on both and the 80 needs it again. Lots of brake jobs on both though.
Butch
254457+ mi.:) 1993
276,890mi
I don't think I ever touched the motor;)
Still have the original PHH (knock on fack wood dash)
1994 Toyota FZJ80
207788 5/4/2002 New
208067 5/4 oil Hav10/30,
Toyfuel inj cleaner
trany oil
t-case oil Mobil1
fuel filter
208625 5/17 Bosch plug wires
NGK spark plugs
210000 7 to 10 center diff lock switch
new t-case
rear main seal
Newfields CV axles (both)
front diff bearings
steering knuckle bearings
newnwheel bearings front
rotor cap
tires Wild Country RVT 285/75/16
brake rotors, all 4
parking brake part ???
Syntech brake fluid
u-joints all
tie rod ends all
nuts, bolts for drive shaft
caliper rebuild rear
bleader valve rt rear
wheel flanges front
speedo gear (correction for big tires)
210710 10/30 thermostat
water pump
front engine seal
coolant Dexcool
front diff seal
ARB Bull Bars (front bumper)
210951 11/14 oil Mobil 1 10w30
213855 12/30 oil filter only
214440 ?/2003 front end alingnment
215119 2/3 sea foam in gas tank
217088 add 1 qt oil (pan leak)
217236 3/11/2003 PCV
oil filter
217453 3/14 check engine light code 71 EGR
sea foam in PCV
sea foam in oil
rotate tires
220088 4/28/2003 oil pump cover seal
220230 4/29/2003 oil Mobil1 10w30
220515 5/3/2003 clean intake chamber, EGR port pluged
EGR gasket
intake chamber gasket
valve cover gasket
MAF gasket
spark plug guide seals
OEM plug wires
valve clearance checked
221591 5/21/2003 t-case leaking
t-case oil Mobil1 75/90
diff oil 80/90 Amsoil (both)
222464 5/25/2003 add 1qt oil
222652 5/31/2003 front diff companion flange & pinion seal
222667 6/4/2003 new t-case, replaced under warr. as it leaked.
front diff seal(MAF)
223377 6/16/2003 TRD airfilter
224319 7/6/2003 left side tires rotate
224584 7/13/2003 oil change RotellaT 15w40,
VSV for EGR
add 1/2 oz Counteract to FR LF tire
seal outside of oil pan, the front part of it
225010 7/20/2003 clean EGR modulator and temp sensor
225650 8/1/2003 Check Engine light came on and off, clean modulator
paint receiver POR15
226085 8/12/2003 new EGR modulator,
rotate tires,add 1/3 qt oil
new rear wheel bearings
mount spare tire used 285/75/16
new SS bolts on cat skid plate
ass 1/3 qt oil
226660 8/18/2003 Slee Sliders w/running board,t-case skid plate,
add 1 qt oil
227419 8/20/2003 p/s line leak return line from gearbox
227455 8/21/2003 Napa 5/8 hose (too tight but worked)
227582 8/22/2003 1 qt oil
227736 8/22/2003 BG44K to gas
229060 8/29/2003 drain coolant remove radiator replace drain plug,
5/8 Gates hose works for return hose P/S injector clamps for clamps
new set bolt for alt.belt
229197 8/31/2003 replace front diff pinion seal OEM and used FIPG(transaxle sealant) on lip of seal
229298 9/1/2003 oil change 0w40 M1
230854 9/30/2003 Dexcool new radiator hoses
231632 10/14 set timing 3 deg
231750 10/14/2003 add 2/3 qt oil
232098 10/26/2003 oil change 10w30 Chevron
232846 11/25/2003 rotate tires, add 1/2oz to the one tire that was short Counteract
232855 11/27/2003 Lucas injector cleaner in gas
233600 12/17/2003 1qt oil, oil pan slow leak, new seeping leak at timing chain cover (now 2 seeping leaks)
234941 1/9/2004 add 1/2qt oil
235329 1/16 BG44K to gas
325704 1/20/2004 oil change RotellaT syn 5W40, oil leaks stoped some time after that
238263 3/26/2004 add 1/2 qt oil
238600 4/1 add 1/2 qt oil
239166 4/11/2004 add 1/2 qt oil
240146 4/26/2004 add 1qt oil
241285 5/13/2004 O2 sensor, cat&front ppe gaskets
241549 5/22/2004 fuel pump
a/c belt tensioner pulley
P.side door stop
oil pump regulator & spring
oil filter add 1 qt (1/4 low)
241997 6/6/2004 Seafoam to gas & oil
242492 6/20/2004 oil change RotellaT syn 5w40
244617 7/30/2004 Toy FI cleaner in gas,
245383 8/11/2004 change coolant ToyRed
245490 8/14/2004 add 1/2 qt oil
new/used front suspension springs OEM (date and mi I did the change ???)
246058 8/28/2004 add 3/4 qt oil
247805 9/18/2004 add 1 qt oil
248644 10/16/2004 unplug port "R"
clean & oil TRD airfilter
249185 10/31 add 1 qt oil
249312 11/3/2004 New front shocks
new P. side front wheel bearings
249680 11/12/2004 ProComp XTerraina 285/75/16 4oz Equal,alingment,
249800 11/16/2004 front R. tire shakes steering wheel, put it in rear no shake,remove tire and spin balance still shake,
250243 12/4/2004 add 1 qt oil
There is more, I just need to update
93 VX Diesel with 230,000 kilometers all Ok except the Aircon
1976 FJ 40 ~ 46,985mi ...don't know how long the 33's have been on...
Strong beast on the trail..... figur' about 300,000 miles in the year of our Lord 2197ad......
Landtoy 80, Wow!
Awesome job of keeping track of PM & repairs!
I just switched over from a 76 FJ40 to a 93 FZJ 80 with 190000 on it & have been planning on maintaining a log like yours.
Nice!
In the past 2 weeks I've installed OME J heavies, cc bushings, extended S/S brake lines, pulled the fender flares, & changed the oil over to Mobil 1 10W30.
I haven't had any regrets about swapping my 40 yet!
I have a fuel log for every gal and price for all gas I pumped.
I need to update that log on computer.
I hate to see how many gal and how much $$$$ I spent on gas.
I should add the parts cost to my maint log.
It would be :cool: to see how much the 80 cost over its life.
92 3fe
clock says 202k but i'm not sure when the po put the 36's on it so i'm guessing it really has on the up side of 220k.... new radiator.... and the po did rebuild the head (not sure why though)
on a side note my two friends beat me in the mileage department.... one is a 92 taurus with 270k.... no major work done so far just water pump, alt and radiator. and my other friends dad still has his original volvo...it was the first car he bought brand new.... has something like 340k on it right now.
225,000, now fresh overhaul...
New colors, too.
91 with 237k. new radiator and water pump @ 185k. new o2 sensors and bypassed the egr system a couple wks ago. runs like a champ. bought her 3.5 yrs ago and have only spent a total of $800-900 in repairs. ($450 of that was the damn radiator)....
'94 174,000 miles with lots of miles towing a trailer that's too heavy for these trucks.
one HG, one cracked radiator, two starters and one alternator, plus all the regular pm.
