Looking for some help identifying a high speed drivetrain vibration, besides a new driveshaft, which didn't solve the issue.
95 FJZ80, 3" lift with 35x12.50r17 Toyos.
Some recent background info:
Was previously running 33" tires on stock wheels. Smacked a rock on the front diff a few months ago while off roading, knocked the 3rd member loose. Tightened the bolts and was able to get it home. Since I was going in there anyways I decided to move up to 4.88s front and rear with an Eaton E-locker in the rear.
Picked it up from the gear shop and they told me there was a pretty severe drivetrain vibration from the front, starting at about 60mph and got worse as I went faster. This vibration wasn't there previously. Since the driveshaft is now rotating a lot faster than before, especially on 33's, I chalked it up to an old worn out front driveshaft that just couldn't hang at those RPMs anymore.
Went home, installed the 35s and tested, vibes still there.
Removed the front driveshaft, locked center diff, tested, vibes gone. Drove it this way for a week or so waiting on a new driveshaft, no vibes whatsoever.
Ordered a new double cardan front driveshaft from Tom Wood's, installed today and tested.
First run up to 70 seemed fine, exited and U-turned and got back on the freeway and right at 60 there it was, same high speed vibe, maybe even worse than before.
It's Friday afternoon so I'll have to wait until Monday to call Tom Woods to discuss with them.
Besides a bad driveshaft, anyone know why the vibes would be there with the front driveshaft in and gone when its not? Same condition with old and new d/s.
Could be a bad balance on the new one, however unlikely.
Could it be the front gears? They're still spinning even with the d/s disengaged, so doesn't seem like that's the issue, but maybe?
Anything else I should be checking or anyone run into this issue before and figured it out?
As I mentioned, I'll be calling to discuss with Tom Wood's and the shop that did the gears on Monday, but in the meantime, if anyone has any ideas I'd love to hear them.
