High EGT values
jblueridge
Near Charlottesville, VA
I’m driving from Virginia and now in Colorado. EGT readings are higher all the time, now maxing at 700C. Altitude sickness?
The mechanical diesels will run rich at altitudes higher than they have been tuned to. I've heard of high-altitude compensators which I think act like boost compensators but I'm not totally sure.
On previous trips I turned the fuel down or understood that my performance was limited.
Thanks
I’m gonna go with Slow Mode.
Apples to Oranges, but I like to keep my EGT's below 1,200F for sustained periods of time. 1hd-fte, Pyro mounted Pre-Turbo. If I'm on a mountain pass, it'll usually go to 1,200F if I put my foot down on the pedal.
This is also here in Colorado.
What engine? My stock 1HDT hits 1450F (790C) on climbs. Has done for over 200,000 miles. No issues.
I live in the foothills.
1hz, TMIC, altitude compensator retrofitted, side exit exhaust: My max EGT post turbo is around 785°F if I really push it with little trailer behind me. But to achieve that I keep it really really lean. Virtually no black smoke ever, but I start to run out of jam above about 3200rpm. Typical day to day on the highway sees between 550 and 625. Around town is 450 to 550 Fahrenheit.
But it certainly doesn't accelerate much better than n/a until you reach third. For me it's been a great trade off and my EGT gauge is no longer the focal point of long drives.
If you're only temporarily at altitude I'd be using a pristine air filter and keeping speeds lower, revs higher.
So, 750⁰c is fine provided you're measuring this before the turbo.
If your probe is behind the turbo, all bets are off
Or if your probe is too short and doesn't reach the middle of the exhaust stream it will always read cold.
EGT measurement accuracy depends totally on who put the probe in where. A/F measurements aren't as common but are more fool-proof.
Yes pre-turbo. Can’t remember how long the probe is.
