Hi-lift disassembly
Central Florida
Is it easy to seperate and reassemble the hi-lift into two pieces, ie, the long shaft part and the ratchet/handle part? I am looking to mount this and it will be much easier if the ratchet part can be stored in the truck while the long shaft gets mounted outside. I have not tried seperating the two. Thanks for any ideas.
mine came apart on its own out on the rail so id say its pretty easy
Don't forget to put a little lube on it to ease the reassy process.
