HG PM + supercherger install = overheating
Calgary
I am baffled again. I got the truck running after a headgasket and the supercharger install. I take it for a test drive and get around the block and look at the temp guage it reads just before red, I here something let go, I see steam, and pulled over as fast as I could. The lower hose on the water pump popped off. I waited for it to cool down, fixed the hose and added water back in and drove the half block home. When I got home I emptied the rad and refilled it with toyota red (it had distilled water in it previously). To refill it I let it idle till the guage moved up from norm, shut it down, waited for it to cool, burped it by squeezing hoses, opened the cap and added more juice. It now wont take anymore antifreeze. I can make it around the block about 5 times, driving it hard, before the temp gauge starts climbing. Now I am concerned that I have pooched a brand new hg install.
I know I installed the tstat correctly, I made a point of it, and I made sure the jiggler is at noon position. I know that the tstat is working - you can see fluctuating fluid levels. I am quite sure that there is no more air in the in the cooling system. This leaves the fan or the rad. The rad is spotless inside when I look in through the rad cap. The block had no crud in the water jacket. No crud ever came out with any of the coolant changes. When I spin the fan after it has "warmed up", it continues to spin for a little more than half a revolution. BTW, it is the ringed fan that came with the kit. The ambient temp was 67*F
I dont know what to ask or what I expect to hear from you guys, the cruiser family, other than change out the fan and rad, but I am loath to throw more parts at it without confirming the problem. Not only that, but it seems suspicious that it gets hot that fast, when it never ever got hot before, even on serious mountain passes.
So, any ideas/suggestions?
Karl
First thought is air in the system, I know you say you burped it, but air hides in many places. I had the same thing when I did the radiator on my 60, did the fill on an incline, etc. still had an overheating problem. It wasn't until I borrowed a radiator fill kit that used vacuum from a compressor that it solved it.
You had to rearrange some collent lines based on the supercharger install. Did you double check those?
As far as I recall the only lines that are changed were the two that lead to and from the TB, the main heater hose. The heater works fine, and I dont see any leaks from the TB. I could open the TB lines up and look for air or use these to burp. Was there a particular thought you had in mind that I am missing Romer?
Karl
I had the throttle Body one leak on me and it overheated. Doesn't sound like your problem.
Do you have a Temp gauge hooked up?
... When I spin the fan after it has "warmed up", it continues to spin for a little more than half a revolution. BTW, it is the ringed fan that came with the kit. The ambient temp was 67*F...
Karl
If this test was done with the motor, radiator hot the clutch is bad. It should have big drag on it, no "spin". How old is the clutch, original, aftermarket or blue hub?
Its a blue hub, but its original with 111000mi on it. An new one costs 300 smackers. How do I salvage my old blue hub? Is this the same procedure as the blue hub mod?
Karl
a new blue hub from Dan is 124.18.
If you want to try and salvage the old one you'll want to cook the the control side. This will be the best way to confirm that the bi-metal spring is still functional and the valve is timed appropriately.
My guess is that the spring is shot or way out of time because you have zero drive to the fan.
Rust affects the spring and can kill it. Rust can also seize up the shaft/bushing where it goes through the housing, then the valve is inop. We cook the fluid pretty good down here, I have seen them full, with an operating valve and no drive, replacing the fluid brings them back to life.
If you want to refurb it, check the bearing, grab the fan and check for play, there should be none. Look for leaks, the most common places are the main shaft (hub) seal and at the housing split. Examine the valve, confirm that it works. If it passes all these it's a good candidate for refurb, if it shows any problems your probably better off replacing..
I would be delighted to order stuff through Dan; however, I live in Canada, and I wind up paying huge brokerage fees, shipping, and really long delivery times. I suppose this is the cost of having freeish health care.
Anyway, I ordered a new fan clutch from a local dealer. My final cost after begging for a discount comes to 254.15, not including sales tax.
It will be here on Monday.
Thanks for the feedback,
Karl
Not to critique you on the tale end because I'm sure you're up to your eye balls in fustrastion, but I think it would have been a better course to take these two big jobs in stages... get the headgasket fixed and make sure everything is operating properly... then come with the SC install. No doubt, there's a higher cooling demand with the SC's, hopefully you can get it corrected with a new moded blue fan clutch. Let us know how it turns out.
:beer:
Rookie2
Folks,
I have concluded that the fan clutch is indeed the issue. I have posted on my website a video of me stopping the fan while the truck is running at operating temp with a gloved hand and spinning the fan backwards. I consider this to be fairly conclusive. Here is the link:
http://members.shaw.ca/karl.norrena/fan.mpg
Frankly I am somewhat embarrassed that I did not catch its condition before I installed it. Oh well.
I would love to buy the fan clutch from Dan, but I live in Canada and have to pay huge brokerage fees, shipping costs, and endure very long wait times (the last part I ordered took 10 days). Toyota Canada get the part to me in 1 day. I begged for a discount and got 15% off. The cost to me was around $250 before sales tax. It appears as though the freeish health care system up here is going to exercised if I keep finding how much cheaper parts are over the border.
Rookie2, your suggestion was my original plan, but unfortunately I am lazy and did not want to repeat work, and I got impatient and wanted to go faster sooner than my original plan would permit. More in truth was that we plan to use the truck to haul our tent trailer over the summer break and I wanted to have lots of room to test the truck. I have been so busy that the original plan would have left little time to test the truck. Am I frustrated? Not even close. The cruiser has not given me near enough issues to get me even a little frustrated. Now getting my Ph.D. in engineering, that was frustrating.
Thanks for your support folks,
Karl
I run an aftermarket temp gauge along with a boost gauge on the drivers side left piller. I would recommend at least the temp gauge for anyone running a SC truck as it does generate more heat and does provide you with the granualairty to see it heating up before it becomes an issue.
...Or just calibrate what you have. An IR temp gun is good for this. I used a VDO guage on a 24 foot camper tow, but never found a good place to put the guage, so I took it out. The guage (without the RT mod) wil show hotter than normal as the truck gets hot, and it will go really high when the truck gets really hot, btdt. IME, the SC alone in the truck doesn't run hotter necessarily, as there is a lot of overcapacity in that radiator. Now those that live at altitude (Romer) will have less overcapacity, especially when towing.
What I have found is that the SC generates a lot of underhood heat, especially at low speeds or in traffic. I'm not convinced that's a coolant address issue or even a fan address issue. Getting heat out on the PS of the engine bay is tougher with a heat pump and the EM over there.
my .02
Scott J
94 FZJ80 Supercharged
skip the IR temp gun idea. You have OBDII so you can scan the ECM directly for the engine temps. People have been putting some sort of scan thing that they can display these readings and it sits right above the steering wheel. A hell of a lot easier than running wires and installing a second sensor and gauge.
I agree, I need a temp gauge. My original plan was to get a scangauge and use that as a temp gauge. This may or may not be a good idea because its easier to flick your eyes over to gauge than it is to read 97*C. The scangauge however has many other uses, I think its gonna win and I may have one in my possesion soon.
So how likely is it that I have damaged my new HG? I know the new ones are more robust than the old, but are they signiificantly moreso?
Karl
The combination of boost gauge and temp gauge have made all the difference for me and my heat issues. When the truck is lugging up a hill I just monitor the boost. It used to be that I'd just hit the gas and use the SC and boost to speed up. The temps would start to climb quickly (and I have a new fan clutch and non-ringed CDan fan mod - and intercooler on top of all that). In a test I kept the boost at around 0 and used downshifting to speed up, no temp change.
I second the non-ringed fan ala Cdan. It really made a difference. I forgot I did that.
