- Joined
- Aug 18, 2011
- Threads
- 25
- Messages
- 136
I have a 4" HFS spring installed on my 40. What would happen if I remove a leaf spring? Would the ride (daily driver) be smoother?
Not sure about the leafs but those rancho's are not helping it at all for a smooth ride
Also, from looking at your pinion angle (front)--do you have your shims in backwards? You want the pinion pointing "up" in both cases to minimize the driveline angle (ie: thick part of the shim should be pointing rearward under the front springs, and forward under the rear springs). Your front driveline angle looks pretty severe.
