For Sale Here is the modified FJ40 you've been looking for!!!
Rocky Ford Co.
I have decided to sell my 1967 FJ40. My family has out grown it and it is time to move to an 80 series with 3rd row seating. I am a little reluctant because I have spent the last three years completing a frame off restoration on this rig and I have owned it since I was fifteen. This thing is very nice.
The good
-POWERTRAIN
-Fresh Chevrolet 350, Tuned Port fuel injection bored .30 over (less than 500 miles on complete rebuild)
-Auto meter gages (2yrs old)
-New Jegs electronically controlled distributer
-New Howell Engineering complete engine management system and wiring harness.
-New fuel pump in custom made surge tank.
-New water pump
-Serpentine belt system from 1990 Pontiac Firebird donor car
-Rams horn manifolds
-Mid eighties GM Turbo350 automatic transmission (rebuilt by local trans shop less 1000 miles) mated to stock 3spd t-case via Advanced Adapter kit
-3speed t-case was rebuilt less than 1000 miles ago
-Vacuum shift was removed and shift linkages from 77 4spd case were installed.
-Rear Axle has less than 1000 miles on rebuild. Due to lack of funds the stock carrier with 10 spline pinion and stock 4:10s was welded per Woody’s instructions in the Wiki. The rear axle also has new Poly Performance Chromalloy 30 spline shafts
-The Front Axle housing is a cut and turned (for SOA) unit from Profits’ Cruisers. It has all new wheel bearings and rebuilt Asco (Asian) hubs. The knuckles were rebuilt and replaced with mini truck large pattern knuckles and new Toyota studs. Longfield lifetime wiper seals, Trail Gear rock ring knuckle felt protectors. The 3rd member is a stock 77 4:10 fine spline pinion with an open diff. The shafts are stock Toyota with rebuilt birfields. Included will be a new Lock-rite for the front. I installed this locker in the rear for one wheeling trip but removed it to put it in the front when I could afford a set of longfield front shafts.
-BRAKES
-JTO Brake booster adapter
-New mini truck brake booster
-New FJ80 (non ABS) master cylinder
-77 FJ55 front brakes with new rotors and rebuilt calipers
-Trail Gear backing plate eliminator kit
-Rear disk brake conversion
-New 90 K1500 rotors with the center machined out to 4.18”
-New A1cardone 79 Monte Carlo calipers
-Poser caliper brackets
-Rebranded Willwood proportioning valve
-JTO soft rear brake lines
-Specter extended soft lines from axles to hard lines on frame
-All new hard lines
-All new parking brake guts and shoes
-STEERING
-Saginaw power steering conversion
-Profits’ cruisers bracket
-Marlin Crawler high steer kit with FJ80 TRE and DOM links
-Flaming river steering shafts
-Custom fabrication by REDLINE MOTORSPORTS
-SOA
-Flipped stock 40 springs up front
-Shackle reversal
-Front shocks / New Bilstein 5150s 12” travel
-Ford F-250 shock towers.
-Rear FJ60 springs and relocated rear mounts for improved shackle angle
-Rear shocks 2yr old Pro Comp 10” travel
-Custom Redline SOA tube fenders tied in to a radiator hoop, front stinger, and custom 2x4 bumper with winch mount.
-Redline DOM tube doors
-Redline family cage built by me with seat cradle system
-Beefy anti wrap bar (traction bar)
-MISCELANEOUS
-New Corbeau Baja ultra wide model suspension seats (made to accommodate up to a 42” waist but still comfy for my skinny wife)
-New Corbeau 40” Baja bench
-Crow Enterprises 3” 4pt harnesses in front
-Crow Enterprises 2” 4pt harnesses in the rear
-Cobra classic 29LTD CB radio
-Painless performance fuse less circuit breaker panel
-37” Goodyear Wrangler MTs on ProComp rock crawler 16.5x10 steelies (spare included)
-New Smittybilt XRC10 winch with synthetic rope (has 1 pull on it)
-custom half doors
-SOR bikini top
-BODY AND FRAME
-all rust was repaired
-interior was sprayed with Raptor liner bed liner (has some chipping mostly from when the roll cage was reinstalled after it was painted)
-every part was disassembled cleaned painted
-frame was sandblasted, epoxy primed and sprayed with urethane single stage black. (Very solid no rust)
-Quarter panels and rockers were wrapped with 3/16” steel diamond plate body armor that was welded solid
-Paint is OEM quality DuPont fleet color Gimmie Green base coat clear coat
-I own and operate a collision repair, body and paint shop all repairs and paint work were done right.
-THE BAD
-Needs a speedometer cable
-Hard top needs restored
-The heaters (front and rear) need refurbished and installed
-Needs a spare tire carrier
-wipers need to be installed
-PARTS
-Heaters
-Upper window frames, regulators and door hardware
-Stock vacuum shift hardware
-Stock ball and claw front axle housing shafts, knuckles, hubs, drums with new wheel cylinders (rebuilt)
-stock seats with new paint on the frames and new upholstery (passengers seat has small tear)
-stock skid plate
-Complete like new SOR 4 ½ “lift kit for SUA configuration
-CCOT HFS front bumper with shackle mounts and new black paint
-Stock FJ40 steering components with new TREs
-I ALSO PARTED OUT A 1977 FJ55 THESE ARE THE PARTS I HAVE LEFT
-Stock front axle housing with small knuckles
-Stock rear axle housing with fine spline 3rd member, stock 30 spline shafts
-2 stock 77 4spd transmissions
-1 stock 4spd transfer case
-drive shafts
Feel free to contact me with any questions. I am asking $16k negotiable
Located in southeastern Colorado
I will deliver the vehicle up to a few hundred miles away, PM me for details.
Thanks Brad 719-469-4845
DUDE!!! You just can't sell that rig!!!
Okay - either way....I've wheeled with this rig before out at CM2010 in Moab...and it's phenomenal!!
Simply a truly sweet rig...and insanely capable!
Best of luck for the sale!!
Bump for a bad-ass FJ!
PRICE REDUCED TO $14500! I bought the wife a new Sequoia today. I must sell this rig! Feel free to PM or email me if you would like more pictures or info.
email is bradbrusuelas@gmail.com thanks
I just landed a new job that is going to require me to relocate. I have to sell this thing right away. Someone please make me an offer. Next stop EBAY.
Had the pleasure of tagging along with the Redline crew before I left Colorado and this thing is a beaut! Bummer to see you have to sell it. Good luck with the relocation!
Evan
Still for sale! I have not had time to get this thing on E-BAY yet but I would love for it to go to another Cruiser head here on mud!
OH MAN! NO WAY! i cant believe you have to sell it. i am sorry to see it has to go. good luck with the sale and glad i could be of help during your build. take care and good luck with the new job!
frank
PRICE REDUCED $13000 I WILL DELIVER UP TO 200 MILES AWAY. If you have any questions or want to make an offer please feel free to call me at 719-469-4845
Brad
Good luck Brad... wish things were different here. I'd love to have it.
Thanks for the note
Bx
