here goes .... OME Spring choices
Purcellville, VA
I've noticed that my rig with OME is sagging a bit and found a sticker on my springs that say they were manufactured and I assume installed in 11/2002. Some say that sprngs last forever, others say 10 years or less with a rig with armor on it. They are the older 860(rear) and 850(front). I replaced the shocks last year with the newer OME shocks.
I'm looking for recommendations. I've looked in the FAQ, Expedition Portal, Cruiser Outfitters, and on Slee's website for recommendations. I have an older Slee Shortbus front bumper with a WARN M12000k winch, sliders, transfer and catalytic converter skid plates, and rear Slee bumper with single swingout tire carrier. I'm running 33" Duratracs with no intention of going larger. I do not have drawers or any other other goodies stuffed in the back other than gear when we are out camping. I do pull a M416 with probably 75# of tongue weight generally.
I'm thinking of the 2850J in front and 2863 in the back. The extra 1'" J in the front will help with the extra weight of the winch and bumper and the standard heavy 2863 should be good in the back so I can keep my existing shocks. Thoughts?
Thanks.
There's quite a few choices available now between Dobinson, OME, Iron Man, Tough Dog, Slee.... That said, I think you are probably over weight for the OME medium springs. I would suggest moving to a heavier rate spring from whichever vender you choose. You can always give them an individual call to discuss options.
I am new to the Cruiser world, had mine one year,
I immeadiatley put on the OME Medium 2.5 Lift kit with the caster correction bushings.
Now I wished I had put on the Heavy 2.5 Kit instead. I say ignore the commenters who say to go with Medium springs. (that is where I got my bad idea from)
I was just up at 4X4 Labs (I'm getting the front bumper)checking out their shop and talking to all the guys who are regulars on the trail. They ALL said I should have gone with the Heavy OME spring set.
No one who wheels seriously goes with the stock or Medium springs. You will be forced to upgrade anyways after you put on a front bumper with a winch and a serious rear bumper.
The guys at the 4X4 lab all said the ride is just fine after you fill your cruiser with food and beer even if you don't have all the expedition stuff on your cruiser. (another 'Cruiser shop in Napa, CA said the same, all the mechanics said I should have gotten Heavy springs)
I have an FZJ80 1996 33" Cooper ST Maxx tires, love them
Go heavy springs.
While I sorta of agree. OME heavies unloaded suck. Despite my armor, winch, 35's, blah, blah, blah, my truck is light compared to a lot and I pack really light. #5540.
I just think there are better options than the OME ones. But then again I have been reading this stuff for years and gone through 3 OME setups.
Yeah, now I am thinking in the future I am going with Slee 4" lift so I can get 37" wheels too. I know I will have to re-gear, but I'll do that when I get my lockers.
I will be looking at some of the newer stuff avail. and not OME.
I'm w/ Retro on this.
OME was great when you had 2 options - OME & Ironman.
Now you can get slinkies, progressives, heck- coilovers too.
Not saying your OME's aren't worth re-buying if you're happy with them, up to you.
I think you may be in for 'L' shocks though if you go J springs, so those new OME shocks are going to be obsolete (which is a blessing if you look at other shocks that fit 80's now)
OME suspension is like CD's - they work, but we have moved on to MP3's, iTunes, thumbdrives, bluetooth, etc.
Lots more money but Icon shocks are droolworthy, even if your budget only allows Fox shocks.
Here's a place to go broke: ICON Toyota Land Cruiser 80 series 2.5 Series Shocks - ICON Vehicle Dynamics
FYI, you can pull off your springs, and spec them out (measure everything) to determine if they have sagged or not. Quite possibly they are a little, or some extra weight has been added, which has dropped them down some.
Thanks. Hadn't even considered another setup. I'm not super excited about tweaking everything with a new setup from another vendor, but will definitely look into it.
What more would you have to "tweak" ? More than likely if you put a fresh set of OME heavies in there its going to bump you up enough that you will need an alignment, same as any other brand of spring. Your brake lines that you have now will still work, sway bar drops, everything. You can run another manufacturers coil and not need anything else.
I'm running 850J and 863J's on my '91 currently. They are second hand springs (unsure of MFG dates) but the rear is slightly (not huge stinkbug) higher than the front. I have no armor on the rear and no added weight back there as of yet.
I just acquired a '97 and I will be running 850J's up front and 863's out back with 35" tires. Will have a front bumper/winch and rear bumper (no swings/spares etc).
I believe this will be the perfect OME setup for my application..
Fair enough. I didn't want to deal with the caster correction of a new setup. I did suspect a new alignment after install. I emailed Mike from Dobinson today. We'll see what happens. I went in and looked at your writeup. I wonder what the long term quality of these are over OME. Time will tell I guess.
If I stay with OME, I think I'll go with the 850J and 863. Thanks.
850j and 863 and 315's. I should have left mine alone at this point.
It's an addiction that never stops. We should all be in a 10 step program that works us towards a Prius.
I own both. Driving the Prius just makes me crave the smack even more!
Hush your mouth heathen! :p
We may be a odd bunch, but thinking like that is what led to metrosexuals & even knowing the term 'guyliner'.
Unless its a budget issue I wouldn't sweat the castor correction much. The plates from Slee, and now i'm pretty sure Dobinsons has them, are a super easy 1-2 hour install. Requires little more than some floor jacks, a few big wrenches, maybe a friend to push on the tire for you. I ran my 850J/863 combo without it for over a year. The truck always wanted to wander about and dove right during hard braking. The plates made a world of difference and I would highly recommend them for the springs you are wanting.
