12mm 12 point socket
Couple of comments:
* I thought about Jerod's trick to hold the cam sprockets when I was doing the timing belt in my Highlander a couple of months ago, but as tight as they were I could tell I was about to shear the head off that tiny 10mm bolt, so I gave up. Next time I'm in one of these engines I'm gonna make a cam holding tool now that I have a welder at home.
* You might wanna look closely at the harness that connects to the knock sensor, that's the sensor that's right in the middle/top of the engine. There's an old TSB on that harness, they wear out and will cause running problems. I don't think the dealer will hand you a new harness for free, but I don't think it's a very expensive part either.
When i do a headjob i usually start with a brand new razor blade and scrape the block deck clean,then shop vac the bolt holes,cylinders and water/oil passages,then a new clean rag with acetone and polish the sealing deck surface clean
I do this to the head(s) and block moments before it all goes together.......this is just my procedure,not the bible but ive never redone a HG
By the way ive got a friends 91 with a 3VZ-E that i gotta do a HG/new heads on waitin in the lot at work......
I hate this motor!!!!!!
I have run into one Cam that was on so tight it sheared the bolt off, I was able to just get it out of the head with the sprocket still on and take it to a shop with a real impact gun, and they barely were able to get it off... If you have the means, make a special spanner to hold the cam sprocket, but if you don't the socket trick works most of the time.![]()
i just bang the nut with the impact gun and it comes right off....no spanner,no socket trick,just a fast 500ft/lbs
Good deal, the hard part is over!!!Just take your time putting it all back together and you'll be good to go!
One tip to keep in mind as you near the end of the project: you'll be anxious and excited to see the thing run, but take your time. The thermostat is on the bottom hose on that engine, so coolant can't flood back up into the engine when you fill the radiator. Result: it can overheat when you start it up the first time (seen it happen). I always refill the coolant by backfilling the top of the engine, thru the top rad hose. Once the engine is full, then I put the hose back on and fill the radiator.
Hey man! Cheers for taking this on, what a nightmareI had a gold 95 4runner with OME and 3.0, sold it before anything could go wrong with the engine.
I would have considered swapping in a 22RE driveline instead, considering
Good write up![]()
