Help with weber 38 and header
Fort Worth, TX
I bought a weber 38 and a header for my F motor a few weeks ago and cannot seem to get in tuned right. It has a nasty whistle when its running. Is this normal? After 5-8 minutes, header tubes from cyls 3 and 4 are glowing which would lead me to believe its running lean; however, whenever I shut it off it diesels for a minute, sometimes backwards. That means its running too rich right? What am I doing wrong? I'm super confused...
It sounds like there is a vacuum leak at the weber adaptor base. Seems pretty common for a weber conversion. Get a can of carb cleaner and lightly spray it at the base of the carb. If in fact the adaptor base is the problem, the engine should speed up (if memory serves me) as you spray the carb cleaner at the base, and you have found the leak. Reseal the base, and follow the directions for setting up the carb again.
As for the glowing header, you may have a compounded problem.
Are you running the factory ignition with this set-up? That may make a small difference too, as well as valve adjustment and timing.
Hope this helps.
often one of sets of fasteners with the adpter plates is too long. it's only by about a thread or two, enough that it won't get tight on the gasket.
i forget which set it is thoug. either the plate to the intake, or the carb to the plate, or the set that holds the two plates.
weber adapter
Use one of these adapters from JTO or others and eliminate those leaks
I had a leak like that on my old OEM carb and it led to the dieseling at shutdown as well. The carb cleaner trick is the best way I've found to determine if that is is the case.
