Help with DUI Distributer Install
Fort Smith, Arkansas
I had a buddy blow his engine last year and is replacing it with a diesel, so I bought his DUI Performance Distributer. I was looking at the stock dizzy and it looks like there is not nearly enough room for the DUI distributer. Anyone have any suggestions on how to install this? Anyone have pictures of their install with a newer FJ40?
FJ40 Dizzy  - 1
FJ40 Dizzy  - 2
FJ40 Dizzy  - 3
Do you remove the heater pipe and replace tiwh a hose? Or bend it out of the way?
This picture was taken from an @wngrog build... His “pig” work is impressive! Looks like he’s already done what you’d like to... ;)
1924972
You'll also need to either get an FJ60 side (pushrod gallery) cover with the dish in it, or bash a dish in the stock side cover you have.
Not sure what you mean by "dish." Can you give me more info explaining this?
The side plate for the pushrods. It is a tight fit with a DUI. You also will probably have to use a end cap oil filter wrench as well since it sits right up on the oil filter on my 1977
The 2F's in FJ60's came with the late "big cap" electronic distributor that ran in ball bearings instead of bronze bushings like 40 distributors. The diameter of the distributor was large enough that it would hit the standard 2F pushrod cover, and the new larger distributor wouldn't stab in or turn, so Toyota made a new 2F side cover with a big enough rounded depression in one spot (where the dizzy goes) so that the new dizzy would fit. Many people call it a "dished" side cover, but perhaps it would be more accurate to call it the "late-model side cover with the rounded depression for a large-cap dizzy".
Looking for a photo of mine, but I don't think I took one before I installed it, and my big-cap dizzy is in the way now.
Here is a pic of the dented side cover installed on my 1F engine.
If you are replacing a dizzy that is worn or has issues you might notice a performance improvement. However if your current dizzy is in good shape, don't expect much if any improvement.
1925584
I went from old school points distributor in my '75 2F to a DUI with Live Wires. I noticed an improvement in startup and a seemingly a little more power, but that could be placebo affect :meh:
I went from a ‘78 oem dissy, with a huge vacuum leak in the vacuum advance module, to a DUI and LiveWires. It eliminated the coil, igniter, dissy and vacuum leak.
The good news...
eliminated the vacuum leak and OLD components, thus eliminating the huge power loss at all times, but especially when climbing above 6k’ in elevation.
My power gain is phenomenal!! But, a lot of that is because of the elimination of the vacuum leak.
However, DUI requires full battery power (no resistor)... so, with full battery power and timing at 12*BTDC and spark gap at .050”, some of the power gain is attributable to the DUI.
The bad news...
it’s difficult to keep my tires on the ground!! :rimshot:
I can cruise at 75mph, at 3800rpm and pass, on a two-lane, at 85mph... with 31” KM2s.
But, I try to stay <=60mph... it’s a rolling stone and has all the inherent handling capabilities of the square-cornered stone that Mr Toyota designed, before the original interstate highways were finished.
I also prefer to enjoy not taxing my eardrums or my engine... the lower rpms (at 60mph) of my finely tuned tractor bring solace to my solitude. 🆒
EDIT: BTW I have a '78 FJ40... I had removed the heaters a while back, so the heat pipe was already gone. My DUI fit fine, with no change to the side cover.
You'd be wise to confirm your buddy's DUI is the Toyota version.
You didn't say why his engine blew... But, early-on, in DUI history, Davis Unified Ignition did NOT account for the slightly different (dissy shaft) gearing for Toyota, than for GM.
Screwed a number of 2F engines before it was resolved.
Before you install it, be sure it's geared for Toyota... If you have a used DUI, it could be from the batch with the wrong gear
There are a lot of old thread about this... And some newer threads... This thread covers it nicely... Start with @Downey, in post #8 and read through the thread.
Downey explains how to ensure the DUI is geared for Toyota.
Just a tip, from your buddy, Dan. ;)
