Help with Dome Light Woes
Richmond, VA
Website
www.vagarage.net
Trying to knock out all the annoying little problems on my truck now that I have the major stuff sorted...
My dome light works if I switch it on manually and it works on the door position with the passenger front door (as well as the lights in the front doors). Nothing happens with the other doors open (driver, both rear doors, tailgate). I have no power or ground at the rear door lights, if that matters (as well as the ignition key light). I have pulled the driver's courtesy switch and grounded the wire and that does not turn on anything (eliminating a simple bad switch). I have looked through the FSM and didn't find anything helpful. Also there doesn't seem to be an actual schematic in there, just component tests. If anyone has a diagram I would appreciate it.
Any ideas would be welcome. I'm hoping someone can point me towards a junction of some sort that may be just having issues as I'm kind of at a loss of how this system connects together. Everything else works as far as the windows and power locks.
Thanks!
I have similar problems.
Download the Electrical Manual. Google "EWD" and "birfmark" it's for 1996.
There are a few connections, grounds, and switches to track down.
You're the man. I'll report back if I find anything.
Have you tried cleaning the door switches? Mine were not working, cleaned with some electrical contact cleaner. All worked after that.
I've changed out the door switches.
One wire job and Bob's you uncle.
Yes to both. I even threw ground straight to the wire with my power probe which should turn on the lights and it did nothing.
I'm fighting a similar issue, I'm interested to hear the outcome.
