I recently swapped out the original axles in my 1965 FJ40 for a pair from a '78. The new-to-me axles have new rotors and rebuilt FJ40 calipers up front and rebuilt monte-carlo calipers and disk conversion in the rear. Everything is plumbed and I have a small booster with a firewall spacer from marksoffroad.net and a 1" bore MC from a 1996 4Runner. I have a Wilwood proportioning valve on the rear circuit.
I've made sure the push-rod from the brake pedal to booster and booster to MC are the proper lengths to not allow too much play but not constantly apply pressure. I bench bled the MC and bled the calipers in proper order.
Everything looks good to my eye and there are no detectable leaks.
When I drive it, I lock up the rear brakes completely if the valve is all the way open (obviously). I've tried various adjustments on that valve and with it completely closed (52% reduction or so according to Wilwood) I don't lock up the rears but can hardly stop. The front calipers have no heat in them whatsoever.
I know I'm getting some pressure through the front circuit because I can at least get fluid out by bleeding and the pistons move with pedal pressure but there just isn't any force.
I swapped the lines coming off the MC to see if that made a difference and it hasn't.
Is there something I'm missing about the front disks? Do I need a residual valve?
Any ideas are a great help.
Thanks in advance.
Thanks in advance.
