I have been looking around my 12ht to fit my aftermarket gauges and it's not looking like a simple install with out losing my stock water temp gauge unless I drill and tap into the water pump housing ?. I'm thinking of running the manual oil pressure from a piggy back system on the stock location ?. The boost gauge is also a pain not sure whether to use the stock pipe or drill and tap another ?. The pyro will be mounted after until I rebuild or replace turbo as put no thought into that when I rebuilt the engine plus don't want drill and tap now and risk metal contamination in the turbo.
How did you guys install your gauges.
