Help Tracking Down 4 Amp Parasitic Drain
I just did a test of why my starter battery drops so low over a night or two and found a 4 amp drain to ground. I pulled all fuses inside and under the hood with no luck. But pulling the fusable links got rid of the drain. Would pulling each of the two connections inside the casing one at a time help narrow things down? Any advice is most welcome.
^^^^^ yup take the alternator wire off and see if it drops when they go, they go
alternator gets my vote
I did the auto window up mod and my battery would go dead in 2 days.
I no long have the Auto Window up Mod.
Power without key on for Sunroof and Windows.
I was going to do the Auto Up on Passenger side, sorry for confusion.
I pulled the Relay and made a jumper to do the power without key
The bulb in the window switch can be pulled to eliminate the power draw.
Well this is just perfect.
If you remember yesterday I pulled everything and got all the way down to the fusable links and that's where I found my 4 amps getting lost. So today I pull each of the three wires one at a time, and ...... NOTHING. None of the three is causing a drain, but ALL of them are!
I'm about to order a battery switch or something because here I am doing all kinds of work to try and maximize battery life and now I have a constant drain that I cant fix. Plus I just switched solar input to the house battery where before it was on the starter.
What the heck is in that AM-1 link box anyway? Just two screws? (It's only 2 years old btw)
There's one small thing though, my DMM reads 4.01 on the amps scale, and 4.01 on the mA scale. Decimal point in same place! I assume this is just a glitch in a ten year old $40 DMM. But could it actually be .401A that I'm losing and not 4 amps? I assume no because the drain should normally be up in the 10-40mA range, not 4mA, right?
And you are using the meter in SERIES with the wire you're testing the current? Set the probes into the correct jacks for current?
You're sure the meter fuse(s) haven't been damaged?
You're sure the meter actually works on the current ranges?
A DC clamp meter is a much better animal for testing current through wires since it essentially is non-intrusive...
cheers,
george.
Show me a DC clamp meter that will accurately read at less than 10A. Realistically, less than 1A if we are talking about parasitic draw.
I've yet to find one that actually works.
So you did a dual battery setup in your truck and now this is occurring? Have you unhooked all that new gear?
Did you rule out the alternator? I think you may be using the meter wrong or it has a issue. A 4 amp draw seems huge to me.
From my perspective I would disconnect everything to start and then connect one wire a a time. You stated you have disconnected one at a time. Are you then reconnecting before disconnecting the next connection? If the terminals or wiring harneeses were not connected properly or if there was a short between circuits you may never isolate the problem by that method.
Also a 4A draw would flatten the battery in a relative short time, not over two days time. I think you need a diiferent meter to test with.
Well, if you are buying 1000A clamp meters and/or junk then yeah, you'll likely have an issue. Knowing how to use a DC clamp meter is also important for finer accuracy.
Why don't you google for Extech MA220. It can readily resolve down to 10mA and in my measurements is accurate to +/- 30mA on the 40A DC range. You have to ZERO a clamp meter and also keep it in the same position as it was ZEROED to ensure stray magnetic fields (since you are measuring DC) don't change the zero reading. The nice thing with the MA220 is that it also can be used as a multimeter and comes with a thermocouple probe as well. Decent all in one meter.
Extech also has a 1mA resolution clamp meter, but the price step up is quite significant.
cheers,
george.
Here goes, I havent hooked anything yet, everything is installed under the hood but waiting for the long line to be laid to the back when it arrives.
#2 My meter doesn't have multiple inputs, just +, - and Temp.
#3 The 4A doesn't "flatten" the battery in two days, it simply becomes noticeable (measurable) that something is wrong by then.
#4 @ PPC - I lifted the three wires together and drain was gone. I then put them back till the next day where I then lifted one at a time at their connections; i e the grey connector and then each of the two nuts inside the box. When one didn't work to fix the problem I put it back before beginning on another.
Sounds like your meter is fooked.
After completing step number 4, did you confirm that you still had a draw after putting all the wires back on?
Oh yes sir I did confirm.
I never really used the DMM for amperage before this project. I had used it for voltage almost exclusively for minor work on DC electronics as in tube amplifiers, checking for continuity and measuring voltage (400V-500V) on the plates. And for this it's always been reliable.
