HELP - Timing gear won't budge
Sandia Park, NM
I know this is the 80-section but I need some help with my 100. There's a lot of experienced people here that might have some good ideas.
I'm replacing the timing belt and wanted to replace the crank seal since I was already in there. But I cannot get the timing gear to pull off the end of the crankshaft. I have a puller on it but am not having any success. I've soaked it with WD-40 and it has sat overnight with tension on it but no luck. I was wondering if anyobody has any ideas on how to get the sucker off. I'm afraid to heat it with my small propane torch because if I can't get the gear off, I don't want the seal that's on there now to be melted.
The last picture shows how the water pump was ready to be replaced. It's blurry but you can see the pink crud all caked up in the weep hole. I wonder if that leak caused a little corrosion on the crank under the timing gear and that's why it's being difficult.
this is
REMOVE NO.1 IDLER PULLEY AND NO.2 IDLER PULLEY.
Using a 10 mm hexagon wrench, remove the bolt, No.1 idler pulley and plate washer.
Remove the bolt and No.2 idler pulley.
REMOVE CRANKSHAFT TIMING PULLEY.
Using SST, remove the timing pulley.
SST 09950 - 50010 (09951 - 05010, 09952 - 05010, 09953 - 05010, 09953 - 05020, 09954 - 05010)
an exert from alldata showing the special tool needed to remove the crankshaft pulley
this is
Yep, that's what my FSM says. My puller works the same way as the SST. Thread the two outer bolts into the gear. Then crank down on the big center bolt. It should pull the gear right off the end of the crank shaft. But it's not moving.
I have a hammer that has soft rubber on one side and medium-hard plastic on the other. I've been using that. But there isn't much swinging room. I need to find a brass drift and try that. I got another gear special ordered just in case I destroy this one but it won't be in until Tuesday.
where and how did you get the idea that WD40 is anything close to being good penetrating stuff?
Use some Kroil or PB Blaster for one thing, let it soak in for a few days....
Well, that's what I had in my chemical cabinet. I should have known better. I'm hoping the Checker/O'reilly near my house has some PB.
Every day the truck sits torn apart, that's another day of nagging from the wife. I told her that I'd get it done in 1 day. I should have known better. No major repair ever goes as planned. She can't park her car in the garage because I have to park the cruiser diagonal to have enough room to work on it and space to lay out all the removed parts. (tiny garage sucks).
I've stripped enough threads and sheared enough bolts to know that I'm close to doing it with the two M6X1.00 screws that are threaded into the timing gear.
If I leave the gear in place, then I cannot replace the crank seal. Inevitably, it will start to leak many thousands of miles before it's time for the next timing belt.
The first photo shows what looks like a woodruff key in the pulley spindle/axle. I know it's farfetched, but I'm just checking... If it is a woodruff key, pull it out with some needle nose pliers & then try to get the pulley off. ;p
The slot isn't a straight cut, it's semicircular. Not enough of the key is exposed to be able to rotate it out. I tried tapping gently on it to see if it would move but no luck.
I'd heat it up. You shouldn't have to get it too hot to crack the bond that is holding it on the shaft. Keep the torch close to the outboard end of the pulley to spare the seal from the flame. Keep the tension on the puller while heating it.
Finally got it off. I soaked it in PB Blaster overnight. Then, I made certain that the puller was pulling exactly even on the two bolts that thread into the gear by threading them in the exact same amount. And for good measure I also warmed the gear up with my heat gun. It came off slowly but it came off. There was a lot of corrosion that was holding it on there. I'll post some photos up soon. Right now I'm just trying to get it all back together.
congrats dude. Now, go invest in some tools and a propane torch. You're the son of a Toyota mechanic for Pete's sake. :D
I was using his tools. And I have a propane torch. I just didn't want to scorch anything.
I'm too lazy to repost the pictures here so here's a link to the thread where I did post the pictures of the rusty crank that made it hard to get the timing gear off.
Timing Gear Photos
