here is the real world of lifted narrow trucks.
7 inches on 33's.
pull into the parking lot at about 20 mph at an angle.
the front right tire rises up and starts to drop just as the left rear comes up.
you find your self on the right two wheels. turn right. find your self on left two wheels. turn left. on the brakes.
come to a stop and thank god that you didn't hit anyone or any thing. completely out of control.
lesson, never pull into a parking lot like that again.
first time side hilling behind a lower truck. the feeling of balance on the down hill wheels and feeling scared because it is a long ways to the bottom.
lesson, center of gravity has real meaning.
pretty girl go's to get in truck and jumps up. yep, split her head open on the top of door frame and landed on her butt on the ground. no second date
lesson, scalp wounds bleed a lot, crying girl in parking lot draws a lot of negative attention. some times they really do have a head ache.
just turning around in the dirt.. ok a little fast, lifting the in side tires way off the ground. eeeeeeeek.
lesson, centrifical force changes center of gravity.
lower truck, trim some bent metal out of the way.
no more scary..
tried 5 inches of lift. nope didn't like it. not as rocky as the 7.
then went to the 3.5 inch lift that gives me about 3 inches of up travel, oil pan just clears my cross over steering with lowered bump stops.
all the off the shelf lifts and springs that I have owned didn't last very long. maybe 3 or 4 real off road trips.
most of the time they turned into some thing that looked like a 3 laying on its back.
the below were on a 85 four runner and the 85 pick up I have now.
downy, sagged way down with out going off road. the shackles laid flat. called to complain and they would only send me longer shackles
sky jacker, road nice, flexed ok, got bent up pretty easy. went through 2 sets.
rough country, road bad, didn't flex, one jump and they bent at the mounts
so I am running alcans all the way around.
3.5 inch lift
front moved forward 3 inches.
rear 6 inches longer then stock.
my wife is running the 4 inch all pro's and they have relaxed to about 3 inch's of lift.
her rears are also 6 inches longer then stock.
that is about all I know about lifts and springs.
I do not know about ifs rigs as I have 4 front solid axles that are waiting for the day I give up and have to buy an ifs.
7 inches on 33's.
no more scary..
3.5 inch lift
im planning to do MUD, mild rocks, camping is good!!!!, and basic OFF-ROAD! i can do bolt on, drilling, cutting, basic mechanics ( RNR )
she good, who build her truck? solid AXLE
i think that's to hard core for me! for sure it works good, u cant complain.... its alot of work for me and money talk....... & my Skillsssss 0% to build a truck like yours, tnx
