btw- missouriman, im still in love with your bumper.
that is bad. having a crush on another mans bumper. hey crazy i am on 31's and i kept up a t raush creek! oh i am going on the big 40 so may be it was a little bit of wisdom.
You should have wheeled on friday
well i do not want to go there. but i did wheel on saturday.
if you want a bad ass truck get a solid axle for $300 bucks get the sas kit for $1200 from trail gear get the 3" springs.
The other problem is we do not recommend a lift of that much unless you're going to huge tires, then we'd tell you that you don't want tires bigger than 35 on the IFS for reliable operation, so it's a no win situation....... You're asking us which wrong way is the best....
You want to play in the mud and do some light off-roading... get a rear locker, and go back to 31 inch tires! None of us want to tell you what lift to get cause it's not the right thing to do.
You came here and asked us cause we know what we're talking about, but you aren't listening to the voice of experience.
you would like my wife's truck also then.
here is a run that we went on.
you can see the advantage of a solid axle and saws all.
https://forum.ih8mud.com/trails-events-expeditions/284610-toyotas-trail.html
's pink rig was brought up again in here, what's it been 5 months?
I still think she paints better than you!
ignore this dude's comments. i've seen a guy with skinny 33" all terrains on an ifs truck outwheel the big boys. even got some video of it. a good driver doesn't need $2k worth of mods.
YouTube - MOV02101
Can I get an "A-Men"? Sheesh, I do what I do on 31's and if I do change anything, I'll only go back to 32's, not 33's, and I'm still not running a rear locker.
Better yet, show us a pic from the front end looking down the side of how wide a set of tires you're running, I guarantee they're much too wide for what you need and the reason they're rubbing at full lock and partial-full lock articulation.
re:
It was only a matter of time before your's pink rig was brought up again in here, what's it been 5 months?
some say she drives better too.
I say she just doesn't worry about breaking, she doesn't have to fix it!!
Nice looking truck. may check out if you can lower the bump stops juat enough to keep it from rubbing.
or you can use some black tape or simular to tape off what you would need to cut. just to see how it would look before you did the cutting.
