Help removing fzj80 elocker diffs
Like the title says I could use some info on how to properly remove the thirds from a 1994 elocked pair of axles. I have the rear all dissasembled but can't figure how to remove the third. Must I remove the locker and if so whats the procedure. thanks in advance for any help or links to the info my searches have become tiresome
I believe it's the rear axle that should be locked before you pull the axles, although it may not matter if you're pulling the third.
If you have the axles out and can't break the seal, some folks jack up the pinion end, some folks pry with a large screwdriver, and some beat on the third with a hammer. I was able to wiggle it loose.
I've removed both axles and have the third seperated from the housing but is seems there is a locking collar or some sort of arm that won't allow the third to seperate more tha half an inch on the locker side. I don't believe it was in the locked postion.
You should lock the axle first. I think that will be as easy as putting a couple of nuts back on the third and tightening them. Then slide in one axle, turn on the key, put in low, turn the locker on, take the parking brake off and rotate the axle you've temporarily installed until you hear it or feel it lock.
Slide out the axle, turn off the key and remove the third. You will probably have to play with it a little, but it will slide out of the axle housing.
I don't remember doing that, but if you guys say so...
Yes, you have to lock the rear diff to pull it. Front doesn't matter. Make sure you've pulled the rear shafts out far enough as well. Last time I did it I thought I had them out far enough and fought with them for about 20 mins before I tried sliding the shaft out a hair more and the diff fell out :doh:
Well that might be a problem becouse the axles are not in a truck and although I have thr harness I don't know how to engage the locker. anyone have a suggestion.
If the diff must be locked (which I still doubt, but...) you can remove the actuator and slide the arm over. There is also a way to lock it with a 9v battery, search this forum for more info on that.
becarefull with the 9v battery trick as you can over run the actuator.
For the rear I would remove the indicator switch, then remove the bolt in the shift fork and then slide the fork toward the center of the diff.
However, if the shaft was pulled prior to locking the axle then the locking collar might be out of positioin and not let the shift fork move. In this case look through the hole where the indicator switch came from and try and work the collar into place so you can slide the fork over.\
Hope this helps
I think I got it. Had the same problem when I pulled my rear carrier. You have to take the cover off the actuator( i think its 3 bolts ) and inside is a screw you have to undo. The screw holds the plunger and thats what was getting hung up. I too had all the bolts out and it would only come out a inch or so. Im pretty sure this is what you are talking about. Let us know. The FSM just says"remove the carrier", whatever.
I'll let you all know later today. It's pretty refreshing to come over to Mud and have all these helpful responses as aposed to the normal BS on Pirate, so once again thanks guys.
OK I pulled the cover that holds the position sensor and exposes the shaft with a collar and bolt. I then removed the bolt and it seems that the collar is springloaded becouse as soon as the bolt disenged from the threads in the shaft the collar moved toward the actuator. I can pry it toward the diff but only a short distance maybe 3/8 to 1/2 an inch. this does'nt seem to move the underlying shift fork or collar. its really hard to mak out what the internals actually are so I'm going to try and find an exploded view of the assembly. I'll get back to you all a bit later.
It's out!! Thanks guys it only took a minute after seeing the diagram. the gears locker pinion all look like new so hopefully someone will be stoked on it.
