Help Primer and Paint Question??
The roll cage is finally getting built and soon it will be time to lay the final coat of primer and paint.
As mentioned in my previous posts we applied expensive metal etching primer. We than laid a top coat of cheap primer and sanded the crap out of it almost back down to the metal etching primer and some places back down to the metal for a smooth finish.
Obviously, we left some high spots of the cheap primer that will be covered with the expensive DUPONT primer.
Long stroy short. I was told that the cheap primer will not mix well with the expensiver primer as a top coat becasue it can lead to premature craking and pealing!!!
I'm concerned becasue I don't want to have to sand the whole truck again.
Those who are familiar with primer and paint, please chime in and help a brother out. Paint guys said it was okay, but I need to be reasurred by the experts of this board.
Thanks.
UNO
sounds like overkill to me,
it doesnt matter what the price, you have make sure the chemicals dont conflict with eachother or youll get carcking and peeling and uglyness.
use a small test area to see what happens,
iknow i used some paint and then i hit it with some auto clear coat and it tore it all up, good thing it wasnt on my truck, but test it if nothing happens it should be okay.
.. this was a problem with laquer basedprimers. it never dries. It evapotrates. as soon as a reducer hits it it swells, leading to crack/lifting it swells under a layer of dried paint and cracks the paint above it make since?
another problem is useing the ETCH primer correctly... if you usted it you'll be fine if you shoot more then TWO very light FOG coats you couldhave problems from that.. not the cheap primer.
On the ETCH primer we used a light fog coat, so I'm not too worried. It's the cheap primer that I'm worried about laquer. It was a very light coat to cover the metal ETCH. Then we'll apply the expensive primer.
I hope it won't peal up?!
I had the same concerns with applying a 2 part primer/surfacer over zero rust. According to the spec sheet on zero rust which is a lacquer type product, the best results were to allow the primer (zero rust) to cure a few days and then scuff. They also recommended doing exactly what lavarunner suggested. Lightly coat the first coat over the primer, let it flash and then start painting. The solvents in the good primer won't reach the lacquer. I had no problems doing it this way.
