Where is the hi-relay for the blower motor. My a/c does not blow air on the high setting only on the first 3 settings. I was told to look and change the hi-relay but I do not even know what it looks like, nor where it is. I did find the regular relay changed it and nothing. Please help, I live in the high desert of california and it is hot. Any help will be appreciated.
) . break it down and trace if you have to. you said you checked/changed relay? make sure there is a signal from the switch first, once that is found, then make sure relay functions right ( thats where i cant help, of course most important step, ) then if good, jumper the fan terminal to make sure it is not corroded or burned and still works. much easier to do i person than to explain. sorry if this just irritates ya more. good luck.
