Im pretty sure the cams are the same. F and 2F that is.
Most likely the machine shop removed the dizzy alignment block and didn't get it in straight. If you have to crank your motor while pushing down on the dizzy then something is wrong. It will slide right in assuming the bore isn't miss aligned or it has corroded.
If it can't go but a quarter inch or so from bottoming out then it's not seated in the oil pump. If it is any more than this then it's an alignment issue. The cure is to pull the pan, insert the dizzy, loosen the alignment block bolts, slide the dizzy the rest of the way, rotate the flywheel and verify the alignment block isn't moving around and torque it back.
If you decide to cram it in there expect to snap the dizzy shaft eventually.
