Help me ID this Distributer - AKA Pertronix doesn't fit
Colorado Springs, CO
Tried to install my Pertronix Ignitor II (Model 91665A) electronic ignition today, but the adapter plate doesn't line up to anything - not even close. So I'm guessing I got the wrong model. Anybody know the right one? I'm told it's a 1975 2F, I suspect it might be from an FJ55.
I'm also wondering what that part is that I've circled in red in the 2nd picture.
If I take off that red circled thingamabob, I may be able to drill new holes in the adapter plate to make it fit. Might even be able to re-mount the thingamabob on top of the adapter plate. If I can get it mounted, is there any reason this shouldn't work?
Thanks!
And finally - is my vacuum hooked up correctly?
EricG
Looks identical the one out of my 1976 2F
The little bracket you have pictured is a damper as far as I know, puts a little resistance on the cam to smooth out the advance/retard movement.
The vacuum is hooked up right at the distributor, you have to have it on the right port on the carb. The vacuum pot is actually for retarding the ignition on this distributor.
Thanks jb
that pertronix kit you listed is for the early-74 distributor and as posted your distributor is from a later model. It does appear to be a 75/76 model year distributor...
there is a pertronix kit that fits that distributor, but since its a hybrid application no one seems to be forthcoming with the info on what exactly works...
I will tell you from personal experience that you can find parts to convert that distributor to electronic pickup with OEM toyota parts from a 5mge work fine. even the vacuum advance canister with some minor mods will work.
It is a 75-mid 76 USA vac retard dissy. There should be no vac hose connected to it. Just run it as a mechanical advance only.
Mark A has the 2 parts needed to make the pertronix fit. Do not try to make the early pertronix fit this later dissy. It just becomes a mess, then when the dissy ends up here someday I will curse you.
Could this explain why it runs rough and doesn't take the throttle well when it's hot? Carb was just rebuilt by Marks Offroad.
Ok, I'll give him a call and see what he can do for me.
Lol - yea, I've had some words for some previous owners recently as well. There ought to be a hippocratic oath for working on these "First, do no harm."
Yes. The vac advance serves to immediately advance the timing when the throttle is cracked open, helping the engine to accelerate. If vac retard is connected to the ported vac fitting, then the exact opposite effect is observed. The moment the throttle is cracked, the engine goes gutless.
Wanna give me a deal on that pertronix kit since you can't use it?!
Lol - the vultures circling already!
Maybe - let me see what works out of this whole escapade.
Ok ... so why is it called a vac retard dizzy if you're not supposed to connect the vac retard port to vacuum? And there is another port on the other side of the diaphram thing - should vacuum be run to that instead? Or just cap all the vacuum ports and call it good?!
Not doubting you, just confused!
And FWIW, the gutless behavior only seems to occur when the engine gets hot.
Because the application of vacuum causes the timing to retard.
USA dissys from 1969 and newer are never connected to the engine directly. They get vacuum at various times through BVSV's, computer controlled valves, delay valves, check valves, etc.
As a matter of fact, yes. The advance can is a later vac retard and advance that has been swapped into a 75-76 dissy. There is a yellow cap barely visible in one pic that is the vacuum advance fitting. That can be connected to a ported vacuum source. It would be a good idea to test the vac advancer to see if it works. It is likely that it is dead (a leaker).
Probably not spark related then.
Ok, thanks for the info - very interesting!
Any idea what the consequences are for leaving that damper out? I believe I can make the adapter plate work, but that damper won't work regardless due to the magnet collar that goes over the shaft.
