CuCruiser
Patient presented with "smoke" at startups, after changing to a new oil. Was using valvoline 10w30 switched to Valvoline Premium Blue 15w40. On pressurizing cylinder #2 to change valve stem seal, I observed bubbles in coolant reservoir.
For a history, Engine has 161k miles, compression OK not great. Desmogged and running well. I replaced the head gasket with genuine Toyota this spring, after what appeared to be the original HG failed. I had the head surfaced at a well-recommended local machine shop. Deck appeared to be completely flat, measured with a brand new precision straightedge, and not pitted. Leak was into 4 and 5 at that time.
Head was warped at least .016" end to end. Machine shop took .020" off and said, "see what happens." I would guess that means it had been overheated at some time. Magnafluxed OK.
Some observations that might help. I have heard gurgling in the heater for about a month or so. I assumed (hoped) that it was a loose hose or something but hadn't really looked into it seriously.
Whatever the leak is, it seals itself at operating temperature. It's only in the last half dozen runs that I've seen a worrying amount of smoke/steam. It steams till you get up around 35 mph, and will not steam again until it has sat at idle for a couple minutes. Then once driving it will stop. Kinda why I suspected valve seals.
I pulled the head yesterday and didn't really see a smoking gun. I did find a finger-sized gob of silicone stuck in one of the passages between the block and head. I had removed some free-range silicone doing the previous HG job. Guess I missed some.
So I would be grateful for advice on what may have been the cause, including installation error. In any case, in light of the history, I would guess that the head is not worth messing with again, and needs replacing? Possibly cracked?
Thanks in advance for reading all that and for your replies.
