- Thread starter
- #21
They have no numbers. They are 34mm inner diameter, 44mm outer diameter, by 39.5mm long. 16 rollers.
OK, I will try to find something out tomorrow. How many do you need?
Don't thank me yet.........my search may not yield any results. However, if I can find a couple for you I will take a case of toilet paper in returnJust 2. Thanks so much!
Hey, it's the thought that counts. I'm pretty sure it is a Toyota specific bearing, but who knows.Don't thank me yet.........my search may not yield any results. However, if I can find a couple for you I will take a case of toilet paper in return![]()
ton of o-rings.Can I ask how you are coming up with those dimensions? My bearing references are not listing any 34mm ID bearings except for one that is 34.925 which equates to an 1-3/8. Are you measuring the bearing or the mating shaft journal and housing bore?
I can't imagine Toyota would have used imperial units for bearings. Let's see what my bearing rep says tomorrow. I will send him the picture and see what he can find with those specs.
Do you have anything that would fit it?
Well, my bearing supplier has given me this info:
Good morning Drake,
The closest option we are going to have is going to be a 35mm x 45mm x 30mm needle roller.
35x45x30 Needle Roller
QTY = 2
$49.52 EA; Stock TN
However, it sounds like Kurt @cruiseroutfit and @Living in the Past have you covered for what you need.
Yup, we have the OE replacement Koyo bearing part# TCB34006 @ Cruiser Outfitters - $18.50/each. We have the appropriate 34mm thrust washers that should be replaced in the case as well.
Good morning Drake,
QTY = 2
$49.52 EA; Stock TN
Probably a bit late to be asking this, but I haven’t seen the thread before just now. How tight is the input gear on the tailshaft of the transmission?
This is a VERY important question because that one gear is proprietary, meaning there is no PN to replace it. If it has cut itself, you are actually better off finding an original tcase to rebuild rather than throwing $$ at that one. It’s really kind of sad that Toyota could sell someone a ticket down a one way street with a non-rebuildable case, but that’s what they did.
