HELP >>>>engine
Yeah, probably just start by cleaning it :eek: .
Probably replace all fluids and filters, all belts, run some carb cleaner through it, new plugs wires cap points and rotor. Give it a chance, it might be fine.
Get her running, then check compression and oil pressure.
McClaskey said:
ok sorry bout the lack of info... i was afraid to try and start her ... its a 64 and my grandfather told me that it does still run .
is there anything i should do before I try and start her up again??
did you read any of the above posts?.... :rolleyes: ...cause there's two there would answer this.
