I am on the downhill side of a head rebuild. I replaced three of the injector plugs on the harness but like a bonehead I did not label the new plugs like I did the originals that I cut off
. I tried to keep the wire lengths in the ballpark, so I am 80% sure which one is which but I'd rather be sure.
I am most unsure about 4 and 5. Is there a way to check the injector firing sequence without cranking?
PS I have an FSM. Discovered the problem at midnight last night and did not check before hitting the sack. If it's in there, flame away-- I'll still be happy. It's bothering me at work so I thought I'd ask since I can't get it off my mind for another 6 hours.
. I tried to keep the wire lengths in the ballpark, so I am 80% sure which one is which but I'd rather be sure.I am most unsure about 4 and 5. Is there a way to check the injector firing sequence without cranking?
