Help buying first 80
As the title says, I'm looking for a 93-97 FJ80, pref one with lockers, less than 180k miles. I previously owned a 1980 FJ60 but it needed more than I wanted to have to do, so I sold it. I ended up getting a 1973 K5 Blazer vert/350 6" lift, etc. It was a bit of a garage queen and I'm now back to LC's as I need a more useable/capable offroad vehicle that I can take my kids camping and (per the wife), something with A/C. (I live in Santa Clarita, CA, where it can get 100+ degrees 4-5 months out of the year)
So, with a stack of Benjamins in my pocket, I'm now looking for an 80. Let me start off with saying, I'm no wrench and I have limited knowledge of LC's or 4wd mechanics. I've done oil changes, basic maintenance, taught myself how to weld and when I was a kid, I use to work on my VW's (everything except motor re-build) so I'm not afraid of getting dirty, but I know my limits. I'd like to know more. For my 80, I'm hoping to add (definition: have someone else do) a 2-3" OME lift, 33", roof rack and lights. VERY basic for camping and occasionally go out to the desert for shooting. No real off roading, but capable. And something that erases the sting of driving a Prius M-F! I've done research online, but wanted some opinions from the esteemed gallery here.
I know the basics of purchasing an old/used car (rust, body issues, leaks, etc.) but have a few questions and wanted to know some key things to look for when checking out used ones. Here's my (yeah-he's-a-noob) list:
1. difference between lockers and no lockers? is it just the convenience of push-button 4wd? would love a link explaining this.
2, head gasket - been reading a lot about blown HG; is there's anyway to see if it's blown? leak, weird sound, loss of power, etc.?
3. trans - other than it not jerking hard when shifting/leaks from case, anything i should be looking at/for? Leaks in t-case
4. for 94-97 models, is there a particular model or factory options that are preferable?
5. difference in 2" vs. 3" lift (i.e., will 33" run on 2" lift without mod; if 3" lift, what mods are necessary, i.e., tranny, driveshaft angle, etc.?)
6. knuckles/birfs - other than leaks, anything else to look for?
I know, some/all of my questions can probably be found with enough searching, but i've been looking at LC's for a few years now...my searches always end up here, so I figured I'd just post my questions. Thanks in advance, and as soon as I pick one up, I'll post pics
First, this link answers most of your questions:
http://www.sleeoffroad.com/newbie/newbie100.htm
The lockers question confused me when I started looking too since I didn't know much about 4WD or wheeling, and the owners of rigs I looked at would say things like 'has lockers' but then it actually just had a CDL. The Slee guide doesn't give a noob explanation of the system.
Basically all of the 80 series have a full time 4WD system. There are three differentials, the normal ones on the front and rear axle, and a center differential. The center one is a viscous coupling most of the time, but when you engage 4-LO it locks up. If you have a 'CDL' switch, you can also lock it up manually in 4-HI, or unlock it in 4-LO. Early models included a CDL switch, later ones can have the switch added easily and if you do the '7 pin mod' then you have complete control over the center differential via the switch.
The 'lockers switch' is a round dial that locks the front and/or rear axle differentials. This is the feature everyone is talking about when they refer to lockers. This feature allows all four wheels to be locked directly to the engine. You only need this in fairly extreme off road conditions. There are aftermarket systems you can get to do the same thing, but it's expensive.
A truly blown head gasket's signature symptom is chocolate milk looking oil. It looks like a melted chocolate milkshake because it is all mixed up with water. Oil in the radiator is a very bad sign as well. Rough idles or foaming from the radiator cap also a signature symptom. If you are doing a real pre-buy inspection with a mechanic, checking compression, doing a coolant exhaust test, etc... you can be pretty sure what you are getting. Most sellers I've encountered don't want to mess with a buyer that goes to those lengths. You get to smell the exhaust, listen to it, visually inspect without taking it apart, drive it and that's about it.
Thank you, yeah, I've printed out the slee offroad article. Helpful but wasn't as detailed as I wanted. Thank you very much sbman. Very useful info. I'm looking at two today. A 97 with a sunroof, new motor three years ago, (65k on motor; 202k on truck) needs new driver seat, $4500. A 1994 with no sunroof, 178k miles, overall better condition, but not a newer motor, for $7200, but possibly a more motivated seller. Hmmmm, decisions, decisions...
Personally I'd want some good details on the 'new motor'. That can mean a lot of different things to different people, and honestly if not done correctly would be worse than the higher mileage truck. Receipts for parts, look at what was put in it, was it mostly OEM stuff, or a bunch of aftermarket parts? If it had a bunch of random aftermarket parts I'd pass on it. Who did the work, was there a warranty, etc...
178K is still pretty low miles for a '94. The Slee guide lists year differences in good detail. Check the coolant and make sure it is proper Toyota red or clean green, hopefully the owner knows the difference, if not be suspicious. What part of the country are you in? IH8Rust
I'm in So Cal, Los Angeles. Yeah, I'm leaning towards the 94
I agree with SBMAN. I might add:
A. if a Toyota dealership rebuilt it I would be comfortable with buying it given all the receipts for work were available
B. If a LC expert rebuilt it I would be comfortable buying it
C. If you can get a LC expert to check out '94 for you that would help
D. Plan on buying the '94 and dropping $3k in fixes and armor and stuff over 2 years
Humbly,
Zona
At the top of the 80 series tech forum there is a FAQ (frequently asked questions) thread or "sticky". Great reading for all your questios!
The 94. I bought my wife a Lexus RX 300 a few years ago with a "new motor". It lasted 2 months and left her and my niece stranded in rural North Dakota after overheating an seizing!
Original matching numbers well maintained is my preference. They are both Fz engines, just a few differences cosmetically (the dash board)!
There's a lot of 80's in the La craigslist also the lx450 the Lexus version of the land cruiser 7 grand for 97 with out lockers is a bit high for La hell there's an lx450 in Glendora for 2900.another one in west La area for 2800. No mater what you buy your going to want to baseline it before going anywhere{maintenance,hose's plugs belts brakes fluids} take your time don't rush.I am sure you will find one to your liking within your budget.
My suggestion is buy a 95.5-97 with airbags. Especially if you have kids you're taking around, or it's a family rig. My wife and a good friend of mine both convinced me to buy one with airbags and I'm glad I did. It gives me some piece of mine. The other thing I would suggest is try to buy a white one. The white paint is a harder paint and had no clear coat to fade and peel from the factory. It is the best factory color and is the easiest to keep clean, doesn't show trail rash, etc. If there's one thing I would change about my rig it's the color. I'd take white over my dark blue in a heartbeat.
Good luck. If you end coming as far north as Thousand Oaks or Ventura to look at a rig send me a PM if you want me to take a look at it with you. I'd be happy to meet up with you and offer an opinion. I'm not an expert but I've had mine for 2+ years and worked on it a fair amount.
-Russell
hey guys (and gals?), thanks for all the info. I passed on the 94. was leaking bad between motor and trans and was using a "lexus/toyota specialist" mechanic. no going for the "new motor" either.
looking at a 2000 (little newer than I prefer) tomorrow. may look at another 94 and a 96 also. all are around 200k miles, give or take and all have maintenance records, so we'll see. not going to rush this. just gonna sit here with my stack of Benjamins and keep looking. thanks again for all the info
