Hi all,
I’m converting my FJ40 2F engine to use a Saginaw power steering pump and running into two issues:
1. Alternator relocation
The PS pump blocks the driver-side alternator spot. I want to move the alternator to the passenger side. Does anyone know an OEM or reliable bracket to do this? Any tips on clearance or wiring?
2. Air cleaner
With the PS pump, the stock oil-bath air cleaner doesn’t fit. I want a good after-market air cleaner that:
— Abraham
2. Air cleaner
- Works mechanically with my new OEM carb
- Uses OEM-style hoses for PCV/infinity plug
- Fits well without interfering with PS lines or alternator
- 2F engine in FJ40, LHD, PS pump bracket installed
- Space where alternator used to be (driver‐side) now blocked by PS pump bracket
- Limited space on passenger side for alternator / housing
- Original air cleaner housing driver‐side can’t fit with PS pump lines / bracket in place
— Abraham
