hello everyone
Went and seen it and there's a few concerning things. First was it was little rust spots on the rear hatch an where the roof rack bolts to the roof. Second was both knuckles needed rebuilt. It ran rough and rich. Probably a vacuum leak. The inside of the oil cap was nasty. It appeared as if it had burnt oil and trans fluid was dark.
Is there a question here? Or are you just telling us that this wasn't one that you wanted? Depending on the price it could be totally in line or depending on the asking price it could be completely out of line.
Thoughts from the experts would be cool. It needs some work, there's no way around it. If everything gos my way I'm probably going to have to change every gasket on the top side. Is the rust normal for those locations? I did drive it a bit and it shifted smooth into all gears and reverse as well as 4l. You can tell its been somewhat neglected and has about 190k miles.
I would say again it depends on things.
I don't think that rust is normal for AZ. Maybe for locations north or close to the ocean.
The valve cover gasket leak is normal. knuckles are normal. The oil under the cap does look dirty long service intervals.
What was the asking price?
I just saw a 1992 for $2800. It looked to be in fair condition as can be expected for something that old. I would suggest, you budget between $1000-$2000 to get everything up to spec on whatever you get in the sub $6000 price range.
I'm probably going to have to trailer it to az. Its in dyer need of tires and I'm need to give it a full service workup after dumping seafoam in everything.
Already there. I can get it plus an ome 3 inch, rebuild the knuks and gaskets and throw on some 33s. I'll have to save the VA disability checks for some slee steel.
Personally I wouldn't touch something with rust that deep, but I'm a spoiled California car buyer so what do I know? I don't have the ability/skill to do body work so I tend to buy things that need mechanical work, which I have the skills and tools to do. I just bought an 80 literally a few days ago. I searched for about 4 weeks, and the craigslist stuff is a minefield. Several actual scams and then anything with lockers was sky high prices, no matter the condition. People wanted way more than I wanted to pay in most cases. I ended up signing up with a broker to bid on dealer auctions and bid on several. A couple I bid on were trucks I had never seen in person (dumb). I ended finding one in Denver that I really liked, and my sister lives in the area, so she and her husband went and checked it out for me. It was pretty clean aside from a very blown head gasket. No rust at all, looks like it's been garaged, a '97 40th anniversary edition. I don't mind the mechanical issues, I've read plenty of threads where people bought 'good condition' trucks and had to do the head gasket shortly thereafter, this way it will be out of the way, and I can build the truck the way I want it. I paid $2750 for it, auction fees and shipping pushed that up some more. I'll end up spending 10K+ on it easily I'm sure with engine overhaul, bumpers, lifts, tires, etc...but I'll have exactly the truck I want.
That's a lot of rust. I'm guessing it's a coastal Cruiser.
I would pass.
I don't know how much it would cost to get it fixed, but I'm guessing it wouldn't be cheap, at least the cost of front/rear bumpers and maybe a winch. Rust free can be had in this part of the country, if you are a bodyshop guy though, maybe it's not a big deal for you. If you don't fix it soon it will only get worse.
I've done a number of projects over the years, and I would say that a mechanical restoration is much easier than a cosmetic one. If I had my druthers, I'd pick a relativemechanical basket case over a rusty hulk.
Its not really THAT bad. Its just those couple spots.
Believe me: that is rust that's got through and under all those rubber gaskets. Imagine what is under all of that. And all those "other spots"...
At minimum you will be cutting four holes in the roof and having to weld in new metal, grind, bondo, prime, paint.
The back window rust is fairly common in non-dry areas. I've seen what that looks like on the inside of the rubber gasket and it's a freaking nightmare.
I'm glad that I don't have any rust. I'd take mechanical issues over cosmetic any day of the weak. It's hard as hell to match 20 year old paint.
If you are going to monstaline your 80 then I wouldn't worry as much about the rust because liner hides a lot of imperfections and you can do the body work yourself without having to be as anal retentive.
Having said all of that...There are plenty of good, rust free rigs out there. Be patient.
Thanks everyone, if the guy accepts my offer after my friend and I found the obvious stuff. My buddy said there was a little rust under the bumpers near the fender well but nothing all the way through. Paint is still covering it. Anyway, it has lockers and 190k.
I thought about it for a bit an thinking back to when I had my chevelle, rust just isn't worth it like you guys said. Unless the guy gives me a price I can't pass up...
