Hell For Stout
CA
Good evening,
any thoughts on CCOT's HELL FOR STOUT(HFS) -FJ40x ExtremeLift Kit? I have a 1978 FJ40 with a worn out suspension that need to be replaced and I am considering... any thoughts? Sale $1,036.47 @ http://coolfj40.stores.yahoo.net/liftkitfj401.html
I love to see some pics of this kit on your rig and please note the size of tires on your cruiser? what size tires would be the best fit? And, any other lift kit out there equally good as this or better? :confused:
Christian :D
Hello,
I have a Hellcreek 4" lift spring set that I just removed from my FJ40. I also have some 2" Conferr lift shackles to go with them. The springs have poly bushings. This setup will bolt right on and be ready to go wheeling. I went with a different setup, so my loss is your gain. $250.00 OBO for the springs and shackles and ts yours, Mudship or pick up in Boulder Creek, CA, near Santa Cruz.
Hola
eric
Hi Eric,
that's awesome! I love to check them out. Would you happen to have any pictures of the part? and the lifted Crusier with the setup?
Is Hellcreek similar to CCOT's HELL FOR STOUT(HFS)?
Chris
Hi All:
I have three buddies that have used the CCOT "HFS" 4 inch lift springs on their FJ40s. All have been happy with these lift springs (can't comment on the shocks.) Two of 'em run 35X12.5 inch tires, the other one 33X12.5
Regards,
Alan
I don't know, I love my OME 2.5 HD set up on my 60, but I've pondered using the HFS on the 40. If you use the 4" will you have to change the angles on your drive shafts?
Just a thought Leather Neck.
One more question.... Where did you get that Eagle Globe and Anchor(sorry, I hate saying EGA) in your pic?
Semper Fi
I have installed a few sets of these lift kits.
1. They ARE hell for STOUT.
2. They ARE hell for Break your teeth on bumps.
3. They ARE hell for STIFF.
I had to modify them (put poly bushings between each leaf, drill for grease access....JUST to get them to budge a little bit.
Now, if you have a winch, 9 buddies, 4 coolers, a roof rack with 3 spare tires, hi-lift, 40" swampers, and a steel body cage, yeah, they may flex a bit.
I would put your money into the 2.5" OME kit from man-a-fre or cruiser outfitters lock your diffs, run 33" swampers and run CIRCLES around the guy with 35's and the HFS kit. Well, he may keep up, but you'll have all your teeth.
Cheers,
dallas
Go with Old man emu got a 4" on mine and it definately the best ride man a fre has them in stock.
I looked for your post describing what you replaced them with, but no dice.
So????
Ed,
I did not replace them with anything! I decided that the cruiser was too high and figgered that just resting the frame on the axles would be the best way to achieve the low rider look. Just kidding see my FJ/BJ mutation thread, page 3( https://forum.ih8mud.com/showthread.php?t=162440&highlight=Fj/BJ+mutation&page=3 ), I replaced the front springs with Alcans and have a set of rear Alcans on the UPS truck heading west as we speak. I just keep adding mods to the original post, kind of a history of mods to the cruiser.
Hola
eric:princess:
Good evening,
Christian :D
I have a set and love them, not sure where the guy had a rough ride issue but with OME shocks mine rides real smooth and has great flex, Highly recomended:cheers:
Hi All:
My three buddies have not complained about a rough ride, and they keep up fine with my OME equipped FJ40 on the trail!
Honestly, the OME springs flex good, but are a still stock length, though with a higher arch (i.e. lifted.) The HFS springs are longer than stock, which seems to work well. Yes, I believe at least one or two of my friends installed lengthened drive shafts with the HFS suspension.
Regards,
Alan
I am still more leaning towards the 4" HFS. I hope it doesn't have any problems. Anyhow, did you not like the shocks it came with the kit or did you minus out the HSF shocks and bought OME shocks? Where can I buy the OME shocks at a good price?
Thanks~
Hi All:
...... Yes, I believe at least one or two of my friends installed lengthened drive shafts with the HFS suspension.
Regards,
Alan
Thanks Alan~ giving me hope! Now, about lengthening drive shaft... is it required? How much more work and cost? where can find/buy parts?
great appreciate :grinpimp:
christian
Thanks~
I ordered the springs alone, but I recommend the bushings from CCOT, they fit better than the stock Poly's I used, then I installed them and ran them with Pro Comp shocks=garbage, called MAF and gave them my lift and details about my lift and they sent out a matched set, the HFS shocks with shackles have alot of drop out so you can ruin short shocks. I dont like the shocks CCOT sells, they are a generic shock that rides like crap, the OME's made a huge difference
I know this is a really old thread but I got HFS kit for my FJ60 from CCOT and with the 4x4Labs rear bumper and a RTT the rear of my FJ60 sits 4" lower than the front, the HFS shocks are fully compressed and CCOT has no fix or recommendations other than sh**canning the HFS and putting in Old Man Emu Heavy duty springs. The HFS are maybe ok for stock FJ60 but anything heavier such as RTT or heavy duty rear bumper with oversize fuel tank and forget it. NFG. I wasted my money. I have ordered EMU heavy duty springs. May be ok for FJ40s.
