Can you guys explain the recurve concept? What is it for?
If I buy a 3fe to use the head on my 2f (and flat top pistons...) should I be looking for an fj-60 dizzy or use the one from the 3fe?
I bought a DUI straight from summit for my 40. It was a plug and play situation. EDIT 69 40 1f engine. Around $300 plug and playAnother question. If you still wanted the HEI distributor, could you take the drive gear from a Toyota distributor and install it on the HEI unit? Is that gear available as a separate part from Toyota?
I know what some of the J**pers have done is get a genuine GM HEI distributor from a JY 250 inline six and then install the drive gear from the J**p 360 V8 on the shaft of the HEI unit. Kind of a self-made DUI distributor.
Thanks. I know that DUI makes a good distributor.I bought a DUI straight from summit for my 40. It was a plug and play situation. EDIT 69 40 1f engine. Around $300 plug and play
It is and it was so easy.Thanks. I know that DUI makes a good distributor.
According to Summit it is the same distributor for F1 or F2 so I am guessing the distributor is the same on these engine????????
Does this do away with the normal external coil and ignitor I currently run on the factory setup?It is and it was so easy.
Yes all for eBay. I carry a spare on extended trips even though it’s pretty bulletproof. Spares aren’t much but all together almost the cost of a whole distributor.Does this do away with the normal external coil and ignitor I currently run on the factory setup?
Any chance you have a link for what you have?Yes all for eBay. I carry a spare on extended trips even though it’s pretty bulletproof. Spares aren’t much but all together almost the cost of a whole distributor.
I used something similar (i.e. cheap unheard of brand bought from ebay) and used it for several years.These seem to be affordable and a few of the folks on MUD have recommended them. It doesn't say that it works on a 1F but most of the threads seem to indicate that the distributor is the same for both 1F and 2F. Is that true?
Will this work on a 1F motor??
HEI Complete Distributor 65K Coil Straight 6 41-62 194, 216, 235, 68-87 Compatible with Early Chevrolet Land Cruiser FJ40 FJ60 2F 3F One Wire Installation Black Cap
A-Team's HEI Distributor has everything you need, all under one cap. With a high-quality aluminum housing and hardened steel dual bushing construction, it is built to last.swperformanceparts.com
My DUI has been awesome. Just make sure that when you get spares or replacements for the internals they don’t sell you v8 stuff. That will cause the same issues discussed above. Runs but lots of misfire and extremely loud backfire.I used something similar (i.e. cheap unheard of brand bought from ebay) and used it for several years.
It worked. Sort of. The engine ran, started and ran. Kept back firing through the carb though. And through the exhaust. And didn't really accelerate fast.
The original distributor appeared to have been updated with pertronix I think, and something about it didn't really look right (like the switch was just kinds loose and poorly installed, I forget) and every time I set the timing I'd drive around the neighborhood a bit to test, come back to the garage, and it'd changed a bit... Got tired of constantly resetting it, and the cheapo chinesse HEI solved some issues, but not all.
Once I started getting really annoyed with the cheapo HEI and began troubleshooting I found the vaccum advance was doing nothing (pretty much just stuck) and the mechanic advance seemed questionable. I finally just spent the money for a DUI late last year, and believe most of the issues are better, but only drove a short bit with it so far due to winter (top off).
How did you get the timing set so that it fires at the right time.I bought a DUI straight from summit for my 40. It was a plug and play situation. EDIT 69 40 1f engine. Around $300 plug and play
Traditionally, I use a timing light, and a vacuum gauge and my ears and my seat of the pants.How did you get the timing set so that it fires at the right time.
Well I have a whole build thread for "Uma" but I just recently got my "new" 2F back from the machine shop. I am going to build it up now that I have all of the parts back from the machine shop. I know about getting the cam and crank lined up and getting the flywheel set to TDC on the compression stroke so that the dizzy can fire at the right time. I am trying to figure out how to get the HEI distributor to fire at the correct time to give it life.Traditionally, I use a timing light, and a vacuum gauge and my ears and my seat of the pants.
Do you mean on a running engine or trying to start an engine with a new dizzy?
If you're having trouble either way, perhaps start a new thread, with specifics and pictures instead of replying to three old threads...
A first-time firing up then.I am trying to figure out how to get the HEI distributor to fire at the correct time to give it life.
