Another question. If you still wanted the HEI distributor, could you take the drive gear from a Toyota distributor and install it on the HEI unit? Is that gear available as a separate part from Toyota?
I know what some of the J**pers have done is get a genuine GM HEI distributor from a JY 250 inline six and then install the drive gear from the J**p 360 V8 on the shaft of the HEI unit. Kind of a self-made DUI distributor.
. To be fair though, it took a fair bit of work to make the freebie HEI (found on a chev engine dumped in the woods) work correctly with the toyota block. The two problems I found being the HEI's oil pump drive too short if you keep the housings flange, and the thrust/bearing face of the block to centerline of camshaft gear are taller on the Toyota - so the gear needed to be redrilled to the correct position. If you don't address those in some way the HEI will likely chew its guts out or possibly wreck the engine. Did my swap about 8yrs/50k miles ago and the only time I've touched the distributor since has been to swap it from the tired old F to the replacement 2F I'm now running.
