HEI and ignition nightmare
Cottonwood, Az.
This was supposed to be an easy conversion, and due to either my igrorance or some epic malfunction, it's been a total disaster. Months ago I bought an HEI diz to do this conversion. It's a 2 wire model, meant for what I gather, a 292. I did all the recomended stuff from the tech article (gear swap, ground off flange..). Anyways, when I removed my old diz, I set the timing BB at 7 degrees BTDC, the rotor was facing right between #3 and #4 spark plugs on the head. Pulled it, the coil/igniter, extended some wires to use for a 12v lead and a ground. Dropped in the HEI the same exact way the old diz came out, with the housing aligned somewhere within a few degrees. I started it. It started, and made some strange banging sounds while it sputtered. I noticed there was no oil press. So I pulled the diz, rotated the eng. back to 7 degrees for reference, dropped the diz in again, still had the bang now and again, but now had oil pressure. Drove down the road, it was missing and banging.
So for the next two days I've checked and rechecked everything - coil, cap, rotor, whether or not I was 180 out. Read the Haynes over and over on the procedure for replacing the diz if timing was lost. 30 degrees clockwise from the #1 position on the diz cap is right between #3 and #4 on the head (just like it was when I removed the diz in the first place) [*Note, the manual says 30 degrees counter-clockwise from the #1 spark plug hole on the cap (which I tried to no avail), and it also says the rotor will turn clockwise when it's inserted into the hole (which is wrong because it actually turns counter) ~30 degrees clockwise from the #1 hole on the diz cap puts the rotor right between #3 and #4 on the head.]
Nothing. It starts hard, sputters and bangs when running anything above idle. I've tried clocking it one tooth to either direction which results in the inability to start. When it was running, I put the timing light on it, and could not see the BB. Rotating the housing either way did not help.
So in frustration, I tried putting the old diz back in. Another mistake I made was not paying attention to how the coil and the igniter were wired. When hooking it up, a ground wire shorted somehow (which originally was ground to the coil mount) and burned all the way to the front of my battery. I fixed that, rechecked everything according to the manual, and now it won't even fire off.
I'm at the total end of my wits! I've done diz work before, and I never had this kind of trouble. The only thing I can think of for the HEI prob, is that I'm not setting the rotor in the right position. But what the right postion is, I have no idea other that what it says in the book. Either that, or for some reason this 292 HEI is not compatible ( but should be since - 1. it fits, - 2. even the firing order on a 292 is 1-5-3-6-2-4) Everything ran great before I pulled the old diz, and if I set the HEI in the same position, I would think everything should be peachy. WTF am I missing???
Stupid question, but the 292 is a straight six? Sorry, but I am familiar with the 235 and the 250(where I got my HEI).
Ed
Sorry 'bout your troub's:frown:
The fact that it starts and runs indicates that the timing isn't too far off, so you should be able to get it timed, if not with a light, at least by ear. If it isn't something simple like the plug wires are bad or not installed in the proper sequence, maybe the distributor is bad or it isn't getting enough power.
The sequence in which I had the wires hooked begins with #1 positioned in line with the #4 spark plug on the head, from there going clockwise 5-3-6-2-4. The wires I hooked up originally went to the coil/igniter. The main 12v was hooked up to the igniter and comes on with the ignition. The ground wire was originally a wire grounded to the coil mount. Maybe not an actual ground? But when I hooked up the test light to the + side of the batt. and touched the wire the light lit, indicating ground.
At one point I was pulling plug wires at the cap and testing the prongs on the cap with the test light. #5 arced across and grounded on the coil plates (a good 1/4"+) wouldn't that indicate plenty of juice?
If it was the diz itself, what exactly could be bad? Ign. module? Are there contacts or pickups that could be dirty? BTW this diz is a reman. I think, straight from Michigan. Is there any way it can be tested?
Degnol, yes, a 292 is an I6, the second biggest Chevy ever made, under the 301.
Sounds like it's 180 out, and sometimes they'll run, sorta', that way.
You had the BB showing and the #1 piston at TDC ON IT'S FIRING STROKE?
The pistons come to TDC twice for each time the spark fires and sometimes the way to be sure which stroke it's on is to pull the valve cover to be sure that #1 is on it's compression stroke. Haynes writes it up pretty well as I recall.
Get it on that stroke then install the distributor so that the rotor points at the #1 wire (it's possible to move the wires around but doing that often makes the vacuum advance clearance a problem on L6 engines).
If you take a distributor out without being sure which stroke the engine's on it can be pretty confusing to reestablish timing.
Honk is, of course, right. But, instead of removing the valve cover, I just stick my finger in the #1 sparkplug hole and crank the motor until it pushes my finger out. That would be the compression stroke TDC. Well, not TDC, but the stroke to find it.
Easy way to find out.
Ed
Ed
Ed is right, of course, and doesn't need to be told to stick it :D.
I like the 'touchie-feelie' method too, but with a gear reduction starter things just move too fast for me.
Ed...JK :)
Pin_Head said:
I have never seen an engine what would run 180 degrees off; in fact they will only start and run within a fairly narrow range of timing
You've probably never tried it. :) I've seen people do it several times, but I wouldn't exactly call it "running". It results in a cacaphony of backfiring, spitting from the carb, and smoke. but it will continue to go without assistance from the starter. Likely eventual death of the engine although I haven't known anyone who let it go on that long, and when I used to administer an auto mechanic practical examination I stopped the testee after his first or maybe second backfire. The element of the test called for the prospective mechanic to remove the distributor and put it on the bench. Then get it running again within 20 minutes. (I'll bet this sounds familiar to at least one person out there?). Many failed and each of them had passed a written exam prior to being scheduled for the practical.
You can get the static timing pretty close by eye.
Rotate the engine until the bb lines up.
Then rotate the dissy until the little prongy things are lined up with the other little prongy things (where the points should be - you'll see what I mean when you look!)
I've seen it. I guess it depends on what you call "running". My experience is that it will only pop and backfire as long as the starter motor is turning it, but it won't run on its own.
Andrew, could you elaborate on the little "prongy things"? Do you mean the ster shaped deal on the diz shaft and the inverted star shaped deal on the floor of the inside of the diz. Is this how you did the install on your HEI?
As far as being 180 out, I did try that, and all I could get was a backfire thru the carb, no running.
So here are a couple of more obsevations that may help with the brainstorm;
when the cap sits on the diz and is locked down, is the contact coming thru the bottom of the cap (from the coil) supposed to touch the the rotor? This one does. If you're familiar with this HEI rotor it has a small piece of metal angled up at the center, running out to the rotor tip. If these pieces are not supposed to touch, this could be a problem of diz and diz cap compatibility, considering this diz was originally supposed to run an external coil.
Yes.
As far as compatability of putting a 'coil cap' on a coil-less dissy - no idea sorry.
Rush, that springy center contact is supposed to ride on it's counterpart. A gap would spark and burn it. I'm not clear on what you are using. HEI distributors I've gone out with have their coils mounted right on the cap as an integrated whole unit. What's this about "this diz was originally supposed to run an external coil"?
Yeah, and I had missed the part about Rush having been able to take his truck onto the road. 180 out wouldn't allow that at it's most lenient! They really aren't running in the normal sense.
[OT - I've had several poor souls have the very distressing occurrance while taking an employment test. At first I hadn't thought much of that part of the test but after a while I realized that it really is an effective way to test a person's understanding of the basic workings of a four cycle spark combusted engine. If they knew, the test was a piece of cake. But if they didn't know they'd be lost as soon as the distributor was out of it's hole. We provided everything needed, including a factory service manual for the test vehicle, and each part of the test was carefully described to them orally and they had a short period allocated to ask questions. The timing started only after they said that they were ready. I weeded out people who may have been good written test takers but hardly knew a distributor from a carburator. That's an exaggeration but I only had one guy who figured it out during the test. I hired him, and about three years later he was one of the best mechanics in the place.]
Anyway, this possibility should be out here. All of it about replacing distributors can be pretty confusing to first timers and even some others. Try to remember how it was, Charlie :)
Well, like I said, this isn't my first time messingaround with dizzies. I've pulled my original at least twice, once replacing all the little BB's in the litle plate at the bottom inside of the diz. I am prone to getting in a hurry and forgetting the smallest of details, so I'm sure it is something along these lines. Ive been obsessing on what the problem could be, and believe me, I've second guessed everything. Right now I just need heads brainstorming, cause my usual go-to guys are out and about.
RUSH55 said:
So here's another question for those with HEI. If you walk out , pop the hood on your Cruiser, and look at the diz from the passenger side fender, where is the #1 hole on the diz cap located? Is it at ~10:00-11:00 or ~1:00-2:00?
Mine is 1:00-2:00
O.K., so I've gone thru and double-re-checked everything from my end, taking care of mechanic error.
Read closely - I pulled the valve cover, set the BB, checked the rockers for movement @ #1, rockers have lash, I installed the diz with the rotor pointing at the #1 hole on the diz cap (which is now at the ~1:00-2:00 position) I ran the sparkplug wires from #1 clockwise 1-5-3-6-2-4, hooked up power wire to cap (red and red, from the diz and from the coil), a chassis ground, and tach wire........... It would not start. It would sputter and pop, but wouldn't light off. I tried rotating the diz housing in small increments one way and the other to no avail.
I rechecked the manual. As I've stated earlier, the manual says to position the rotor at the #1 hole on the cap, then rotate it counter-clockwise approximately 30 degrees. I did this...... Still no fire. I rotated the housing in small increments both clockwise and counter, to no avail.
Have I missed something??? Does this sound like a prob. with the diz itself?
