O.K., so I've gone thru and double-re-checked everything from my end, taking care of mechanic error.
Read closely - I pulled the valve cover, set the BB, checked the rockers for movement @ #1, rockers have lash, I installed the diz with the rotor pointing at the #1 hole on the diz cap (which is now at the ~1:00-2:00 position) I ran the sparkplug wires from #1 clockwise 1-5-3-6-2-4, hooked up power wire to cap (red and red, from the diz and from the coil), a chassis ground, and tach wire........... It would not start. It would sputter and pop, but wouldn't light off. I tried rotating the diz housing in small increments one way and the other to no avail.
I rechecked the manual. As I've stated earlier, the manual says to position the rotor at the #1 hole on the cap, then rotate it counter-clockwise approximately 30 degrees. I did this...... Still no fire. I rotated the housing in small increments both clockwise and counter, to no avail.
Have I missed something??? Does this sound like a prob. with the diz itself?
