After reading this:
https://forum.ih8mud.com/threads/diy-replacing-heater-hose-pipe-ts-important.610334/
I decided to change my heater hose T's today. I figured it wasn't completely necessary yet since I have a relatively low mileage 99 LX (125k on the clock). But it was a rainy day here in San Antonio (for a change) and I had nothing else going on after bleeding the AHC system and replacing the cabin air filters (they were NASTY). I bought OEM T's from the local Lexus dealer.
Long story short, it's a very good thing I changed them. The hot side T was so brittle that it simply fell apart when I tried to loosen the first clamp. Here's a pic of the two old T's.
There was MAYBE a sign that the hot side was weak. I say maybe because there was a very slight bit of dried coolant where the hoses met the T. That's it. And I really had to look hard and use a bright flashlight to see it. Otherwise, it looked and felt ok until I tried to loosen the clamp. By hand, it felt fine.
So, I did some reading again in that thread I posted above so I could see if there's a pattern to this failure in terms of years and mileage.
Some members found NO problems with theirs when they changed them, per the thread above. The following found their T's to be ok:
1999 with 180k
1999 with 125k
1998 with 112k
2000 with 153k
2003 with 120k
However, other members had bad T's:
1999 with 135k
2003 with 123k
And of course my 1999 with 125k.
Long story short, if you're reading this and you have a 100 series with, say, 90k or more on the clock, change the heater hose T's asap. Do not wait. Some models of the same age and mileage will be ok, and others will not be.
Matt
1999 with 180k
1999 with 125k
1998 with 112k
2000 with 153k
2003 with 120k
1999 with 135k
2003 with 123k
Matt
and an ignition cylinder, and a transmission, and a brake master cylinder, and a front differential, and a timing belt, and a throttle position sensor, and...
