Heater cowl vent info needed
Stanthorpe area, QLD, OZ
Hi all, I'm looking for info about the heater cowl vent that seems to be a feature on older 40's. I have a fibreglass tub that is moulded with out any of the normal slotted vents located on the tub cowl between the doors and the front fenders. You all know the ones but here is what I have now:
What I am hoping to do is replace this raised blank area with one of the older style cowl vents that are the removable type. I have seen two styles. This diagonally slotted one like on Hawrdriver's 40. He also has a fibreglss tub and the vents were done by a PO on both sides - https://forum.ih8mud.com/showthread.php?t=65551&highlight=ROTW+hawkdriver :
Or one like this of Krzyabncanuck (over in the 45 section) with horizontal slots - https://forum.ih8mud.com/showthread.php?t=53893
So that is what I want to do. I love my fibrglass 40 but surfing mud makes me want my cruiser to look more "cruiserlike"!
I want to track some of these "detatchable" vents down but would like some info on what year models these came from. I can't ever recall seeing them in Australia but I could be wrong. Havn't found any aftermarket suppliers yet, (all the usual places), so it may have to be second hand, private sale, etc.
Any info would be greatly appreciated. Thanks,
Lup:)
My '71 came with the removable vent on the passenger side and no vent on the driver's side. So, you could look into someone parting out late 60's - early '70s FJ40s and use the passenger side vents.
Same thing here. My '67 has the horizontal sloted vent on the passenger side.
Diagonal slotted vent was used on pre 1966 40 series...It coincided with the introduction of the heater option in the truck from the factory somewhere around 1964...after that, they were horizontal...both were removable until late 1971....after that, they were made part of the kickpanel and not removeable.
:beer:
Awesome info guys, just what I was after.
Thanks, Lup :)
I think there are actully 3 styles of the removeable vents, I forget the difference on the 3rd one........I knew once ;)
nuclearlemon said:
oem, there is a recessed area where the vent bolts in though. might look funky on the fiberglass unless you graft in that area.
I have cut that area out of a later cruiser so I can graft it in to an earlier cruiser so it will look stock. I really like the diagonally slotted vent and wondered why Toyota dropped it so early, was it because of air flow or so they only had to make one for right and left hand drive vehicles. In 64 the side vent only can on the cruisers that had the factory heater installed. By 68 and maybe earlier all FJ40s imported to the US had the front heater installed with side vents. The 45LV I had and the 45LPB I have did not have the factory heater so no side vent. Like Steve said starting with the 72 model they were stamped in the tub on both sides. The driver's side were used for the manifold cooling fans.
My 63 FJ40 has the defrost vents in the windshield and my 61 didn't. So sometime between 61 and 62 Toyota started adding the defrost vents in all the 40s. There are a couple of us 25 owners who have Nippon Denso heaters in our 25s that have defrost ports on the back but no defrost vents on the windshield:confused: The 25 parts book don't show the Nippon Denso heater so who know if the heater was installed at the factory or just added and happen to be the Nippon Denso.
John
Yes, I've been thinking about that, but I think it will be doable. I will have to chop enough of the fibreglass so that the vent plate will sit flush with the body as per OEM. I dont want to just mount it over the top of the body so to speak. Getting it all to fit and being able to fix it to the fibreglass will be the challenge.
Now that I know what year models had them I'm half way there.
Thanks again all, Lup:)
