Headliner Removal and Installation
Portland Maine
Website
www.dogwashetc.com
I have not found much information on the forum regarding headliner replacement. Maybe someone has some advise or do's and don'ts on the removal and replacement of the headliner? Most of the posts I've read on this subject claim that it is a PITA. I don't doubt it. I have a 1991 that has a god-awful headliner in it. I also have a 1994 with an immaculate interior and beautiful headliner. I have painstakingly, over the last few months, installed the 1994 interior into my rust free 1991. This project is now paying off and looks great but to complete the job the headliner must be swapped.
I have begun to remove the pristine '94 headliner but I have come to a standstill. The headliner edges are glued to the pillars. The glue probably won't be too big of an issue as I think a heat gun will help loosen the glue. The other issues I have is the headliner is also tucked under the windshield gasket and the two rear sliding windows. If anyone has removed the headliner in a '91-'94 please let me know your experience with this project. Do you have to remove the windows to free the headliner? Thanks for any input guys!
Why not get a headliner from a 95+ and modify to fit? There was a recent post about someone that installed a 96 in a 94 and he reviewed all the things that were different.
Thanks for input. To answer your question: I already have a free, pristine replacement.
I understand that, but the headliner in 95+ are one piece foam/fiberglass moldings, not the PITA of the earlier models. Many folks here want to ride themselves if the types of headliner you currently have to upgrade.
Just throwing that out there.
Good luck!
Maybe find one cheaper than the amount of labor you'll need to R/R the one you have.
have you gone any further with this? I can't find info on even taking part of the headliner down to access the roof rack holes, which I am wanting to get welded up.
Yes, to properly remove and or reinstall a new one you need to take out the windshield and rear side windows. You could do it without removing, but it wouldn’t be perfect. The early 80 series ones were very similar to the 60 series one we recently replaced. Long and labor intensive, but not very difficult.
that looks really nice! hmm. I will have to do some planning. Need a new front windshield anyways so that helps. Where does on buy a new headliner?
What would you like to know? I did the removal and replacement (it was a bitch) and it came out awesome! Also had my roof rack holes welded while the liner was out.
You are among legends.
Did you go back in with the same style liner or did you do the update?
Haha, I went with the fabric and rod supported liner. So yes same style. I wouldn't want to do it again...ever but it was very rewarding when I did it. Since I took out the front windshield and rear sliders I decided to replace the rubber seals at the same time which they seriously needed anyway.
I think I am going to redo the seals on my rear sliders this fall. I am just going with new rubber. Everything else should be good. I avoided a sun roof snafu by tossing in a used one, but something tells me I am eventually going to tangle with the headliner. Good to know that people have lived to tell the tale;)
Windows are fairly easy, just make sure you use synthetic rope/cording to get the windows back in. I probably don't need to tell you to use OEM. Let me know if you have any questions, I'll answer them as best as possible.
Jen and cruiserhound are correct. Just like the 60 (less the sunroof) and not too much fun. I just did this on a HDJ80 build. Welded up the flare holes as well. We cleaned the original liner and I’m about to install it. Did the one on my 60 a year or so ago. And after pulling the 80 liner I can tell you it’s a lot better made than the 60 one. Also, make sure you remove all the insulation before welding...it will definitely catch on fire :).
Jen and cruiserhound are correct. Just like the 60 (less the sunroof) and not too much fun. I just did this on a HDJ80 build. Welded up the flare holes as well. We cleaned the original liner and I’m about to install it. Did the one on my 60 a year or so ago. And after pulling the 80 liner I can tell you it’s a lot better made than the 60 one. Also, make sure you remove all the insulation before welding...it will definitely catch on fire :). View attachment 1669399View attachment 1669400View attachment 1669401
meant to add a view after welding and paint. Sorry I don’t have any of the top. But all holes
are welded up.
