Headers
The Ghetto
I have a SBC 305 in my 72 40 and I need new headers. They're rusted out and leaking. Now, these look like special headers that were made for the conversion but i'm not sure. For you guys out there with the same conversion, what would be my best bet?
i saw a thread on here, someone said hooker headers makes a header that hugs the block and drops straight down, and if i remember right,(im gettin old) hooker makes good stuff too .:D
Check them out, Good luck ..
I do not see anything.....
There are many options out there for " this conversion ", however, posting a pic of what you have, may help narrow things down to a style/vendor, or possibly, you may even be able to switch back over to cast iron manifolds...
Downey sells headers...
AA sells headers....
:beer:
I got a pair of Hooker Headers (Block Huggers) that are in used condition, need some paint, and are in great condition..
I was planing on putting them on eBay in a couple days or so..
But the way you say special headers I think you may be talking about the outside the frame rail headers..
Like these..
Hooker makes a center dump header for cheap. Sanderson makes some real nice ones but they are kind of spendy. The hookers are available at any Hi-Performance place, but I could only find the Sandersons at Century Performance online. I am sure they are available other places too.
I have had problems with headers...rusting though, cooking the crap out of everything under the hood, leaking..get used to tightening them down everyday. The over-the-frame-rail-style headers made by Slick-Fit sold by Downey, Advance Adapters and probably others are an aberration. You gotta hack the crap out of the inner fenders to make room. I have run GM center dumps/rams horns for 15 years and they are near bullet-proof. I used the Eastwood cast iron high temp paint and it lasted about 20 minutes. The ceramic coating like Jet Coat is pretty durable but spendy. About $200 for the set, IIRC and includes surface prep but no cleaning up of the casting marks, etc.
http://www.jet-hot.com/
http://www.classiccoatings.com/
I wrap the pipes from the manifolds to the mufflers with header tape to keep my rubber floor mat from melting to the tub and fab'd heat shields under the floorboards like the OE muffler has in the rear. It still gets hotter than heel but every little bit helps.
x2 on the Ram Horns..
That's what is going in my cruiser (hints sellings the headers)
I'am ceramic coating the ram horns just because..
I got my ram horns from A1auto or AA1auto something like that, they are on the web..
They have aftermarket ramhorns that are alot beefier and heavier than GM ram horns, plus they were only like 50 bucks a piece..
Some more pics for reference. These aren't block huggers, obviously. Are they the frame huggers....is there such a thing? Also, they pipe meets up with the header outside of the frame.
Take those headers off and throw them in the garbage.
Get a set of ramhorn exhaust manifolds.
Headers are alot of trouble.
I told this same story last week.
Working on a buddies dads 67 Chevelle.
Hard to get spark plugs out. Because of headers.
Had to change starter. It was a bitch. Because of headers.
Has to be a small, high torque, high dollar starter than you can index and change position of motor. All because of headers.
Burned up a spark plug boot. Because of headers.
They blow gaskets, if not properly tightened and often.
Unless you are building a hot rod. You'll never know the difference in power.
We were all bitching about the headers before we got done.
However, a V8 will sound better/louder with headers than exhaust manifolds.
JR
jackbrad said:
Not to be insulting .. those Headers look are junk.. I would worry about those under my hood.
That's why he is trying to find a replacement.... :rolleyes:
