this weekends project: Painted my ugly headers
SoCal - westsiiiide
so, I painted my headers this weekend. (let me preface this by saying I hate painting.) I spent at least an hour sanding them both down. that was a real pain itself trying to get all around them, but when I did the surface rust came right off. I then blew out the engine compartment with my air hose and then washed the headers down with soapy water. so, they came out pretty clean. After, I started to try to tape off and cover the engine for over spray. that really sucked and I admit, I did a so so job as there are places with a little over- spray on the engine block where I didn't seal good enough. But, I can clean that up. After they dried from being cleaned, I then started to paint. that was also tough with all the twists and turns, tight fit, limited space, can needing to be upside down, etc. but, I got it done. Then, to cure, I drove around for about 30 minutes to get the heat up and let it cure as I drove and it then sat hot for a bit.
I used some black, high heat (1600 degrees) engine/header paint from Pep Boys. In total, it took a good 3 or more hours just to prep, clean, tape, paint. But, it looks 100% better. wish they were painted black while off the engine, but... oh well.
BEFORE
AFTER
And then it all burned off when you started it?
I have yet to find header paint that really works well. I've tried eastwood, por15, and a couple of other high dollar coatings, with sandblasting and prep first...
I hope your long term results are better!
bummer to hear that. well, it lasted through the day. I guess we will see. Jeez, if the por15 did not take, that makes me nervous. I used a brand called Dupli-Color (High Heat with Ceramic). I'll let you know. that will suck if it falls off.
POR's pealed off for me, too.
Looks nice.
The paint on my headers is 2 years old. If the timing is too low the pipes will get HOT and the paint will be history. Once the timing is set you should be fine.
Edit: the paint I'm using is paint for wood stoves.
Holly :censor: sure as :censor: it already started peeling off today right at a major bend in the tubing (the farthest left in the top photo). what a bunch of :censor: and waste of time (the worst part)/money. that pisses me the :censor: off. but I guess I learneded a lesson. :censor: !!!
I guess I should have asked before I did this.... but I assumed said products would work.
In all my years of hot rodding I have never, NEVER seen anything the home guy can do to paint headers. The wood stove paint is the best idea yet. I have seen the header wrap products...knocks down under hood temps and doesnt look all that bad, but some say that it damages the headers by not allowing it to cool properly. I don't know as I have never used header wrap. A friend of mine used to own a local Car Quest and when he built up a camaro, he ordered Duramax headers with a "lifetime" coating on the header that was never susposed to burn off....6 months later he was sending them back under warranty for just that, coating coming off....He did this at least 3 times that I know of. I feel for ya......
Rice said:
Looks nice.
Hey Rice,
Where did you get those valve covers from. I have seen those before, but havn't been able to find a place that stocks them. I checked with Summit, Jegs, etc.. but nothing. Thanks
my64fj40
What about those ceramic coatings that you send the header out for?
A buddy that runs a header in his FJ60 just went through the futile exercie of painting it, lasted about a week. By the time we got to Roundup the paint was cooked and peeling off in scales.
He'd wrapped an earlier header and found that moisture (from condensation?) got under the wrap and rusted out the header.
this one reason alone is why I did not go that route. I DID do research on wrapping headers last year as that V8 puts out so much heat, you can feel it through the floor boards and it can friggin burn your feet (even melted some cheap floor mats). But, I made some cool floor mats out of that EVA sponge material you use on your floor shop for standing on, and that cut the cabin heat and takes the heat fine.
So, I guess it was just a futile effort. I seriously never really thought it would not hold. High heat paint + high heat headers = nice paint job right? yeah right :flipoff2: I even feel kind of stupid now for doing this. So far, this has panned out to be the biggest bomb of a project/improvement I have tried - and in under 72 hours.
do not use wrap on your headers, i used thermotec on a set and they did cut down heat but they also made the headers brittle becuase they pretty much cause the header to cook itself. They are meant for engines that dont see long runs or used as a daily driver. for racing purposes only. Ruined a set of headers, worst mod i ever did. should put it in the worst mod thread
Man, I was going to order some paint form Eastwood the next time I get paid to do just this.:rolleyes:
I tried several coatings on the header pipes of my motorcycles but the only thing that actually is able to take the heat is ceramic coating but I had to have this done, it wasn't something that I could do myself. It's probably dangerous as hell to spray anyway.
If you read the back of the high heat duplicolor can or ask someone at the autoparts shop, youll find that youre supposed to let the paint dry then throw the painted headers in the oven on 300 degrees for 2 hours so the paint will be baked on. This way its heated from the outside in, unlike when you start it and it heats from the inside out, therefore boiling the paint off. Kinda makes sense. Sounds like im having painted header for dinner tonight!
I used the same paint and it peeled off in about 3 hours of driving. Atleast you'll always have your pictures.:crybaby:
