head gasket any ideas
Hello from the other side of the pond!
I have a 95 1fz-fe with 172 .000 miles .I have just blown the head gasket.
As iI now have the head off and at the machine shop Does any one have ideas on WHAT parts should I replace now that I can get to things ?
:cheers:
thank you
PHH and other Heater hoses & clamps
Fuel filter
Have the injectors serviced
Replace vacuum hoses
Clean throttle body and MAF
Replace any of the notorious 0401 code EGR components if needed
Replace belts with new Toyota matched set
Clean battery ground connection on block
I'm sure somebody will chime in with more.
Just to tellyou all new head on goes gret .The old head was to expensive to repair. the water way on the rear of the engine on no 6 had corroded so blowing head gasket. head I got was £200 polished and ported with matched inlet manifold. No brainer realy . replaced all hoses belts and cleaned maf and egr.
