head bolt check Q
Albuquerque, NM
can anybody give me the info on where on the bolt and the diameter measurement for checking head bolts for reusability? a friend is looking for it and can't find it. thanks,
Shawn
some more info, my buddies head gasket went and he's having it replaced. CDan told him the head bolts could be reused IF they met a diameter minimum at a certain point on the bolt, but didn't have those #'s at the time. they are working on the truck at this time, so i'm hoping to find the specs fairly quick. a search found nothing. thanks guys.
From page EM-26 of the FSM, I get:
Standard OD (measured on the threaded portion): 10.85-11.00mm (0.4272-0.4331")
Minimum OD (measured on the threaded portion): 10.6mm (0.417")
See attached PDF file.
28. INSPECT CYLINDER HEAD BOLTS
Using vernier calipers, measure the thread outside diameter of
the bolt.
Standard outside diameter:
10.85 – 11.00 mm (0.4272 – 0.4331 in.)
Minimum outside diameter: 10.6 mm (0.417 in.)
If the diameter is less than minimum, replace the bolt.
Shawn what in the world are you doing on this board?
I bet you secretly want an 80 and you are testing the waters.....:lol:
i have been half way looking. Jill wants something more family friendly for basic camping. only problem is, everything is paid off right now. mortgage and utilities are the only bills.:grinpimp:
I knew you or beowulf were going to make a comment about me being here.:lol:
Get an 80 for Jill. She and Sarah can get out and tear things up.....:eek:
