BrickRunner
Supporting Vendor
Do you know if the wiring harness is from the FJ62, the HJ61 or a mishmash?Hi All-
Interesting update: I discovered a strange sound originating from the front of the engine only to eventually hear a crack and a pop! Not sounds that are particularly reassuring. After some extensive poking around, I eventually discovered there was a hole in the timing belt cover and noticed the pulley connected to the IP was making contact with the plastic housing. Not good.
I took off the cover only to discover that the previous owner--in his genius--decide to reattach the pulley with a mere single fastener, rather than the four that it requires! Rather happy I was able to catch it and mend it before the issue grew more catastrophic! The poor remaining fastener was finger tight and hanging on by a thread, so I am very grateful I caught this. I have a new plastic cover/housing and gasket on the way.
In any case, got it all back together and took it for a spin now that I have proper coolant temp on the dash. Stoked to take some laps around the neighborhood with 'er!
I'm noticed an unacceptably high voltage on the alternator circuit (~16V) so I need to figure out what the deal is with that. The alternator connector just slotted into the alternator, so I assumed there was not anything else that needed to be done for voltage regulation. Perhaps that was an incorrect assumption. I have it disconnected for now so I don't overcharge the battery.
My HJ60 originally had a external voltage regulator but a PO had converted it to an internal regulator without doing the necessary rewiring/removal of this connector by the left hand fender and it gave me erratic high voltages.
