HDJ100 electrical connector identification (need help)
SW Idaho
I am trying to identify the connector part number for the slide on connector for the oil pressure sending unit on a 1998 HDJ100. Oil pressure sending unit has a button connector. I have searched the 1998 EWD, a 2007 Toyota wire harness repair manual, google/www and Grok and I cannot find the part number. I have a used engine wire harness from Russia and it also has the same connector. Any assistance is appreciated. Merry Christmas to you and yours.
I have found that a standard female automotive crimp can be made to work on an Oil Pressure Sender..
TreadingLight, what you provided looks good enough for a repair on the original harness. I really appreciate it. Merry Christmas
Full EWD has the connector for the oil pressure sender listed as part number 90980-10703. Can't really find any pictures on google to compare to yours so you'd have to order one to find out if it matches.
I forgot to mention, the keywords that helped me narrow it down included ".250 button terminal".
I also found one on ToyotaMatt's site: ( Single Wire Type ) TOYOTA Oil Pressure Sending Unit Sensor Switch Connector Wire Harness Repair Kit - VintageTEqParts.com - https://vintageteqparts.com/products/oil-pressure-sending-unit-sensor-switch-connector-wire-harness-repair-kit-single-wire-type
And this terminal on corsa technic looks like a match, but I don't see a connector housing for it. If I am right and this is the correct button terminal, it crosses over to Toyota repair wire 82998-12070: - Sumitomo | 250.ATL-SKT - Corsa Technic | 250 Series Socket Contact (Alternate design) - https://www.corsa-technic.com/item.php?item_id=834&page=g&category_id=111
I've never seen the exact plug the OP shows and it is most likely not available from Toyota.
The 60 Series oil pressure sensor connector (which is posted above) is available from Sumitomo vendors, and is what is shown on ToyotaMatt's site.
The terminal is indeed correct.
By chance, I repaired both the pickup and ground wires yesterday on my harness. Terminals are new, but I re-used the original connectors.
