HDJ-81 Brake Fail!
I have a Toyota LC HDJ-81 with 1HD-T engine. While driving on a hilly area, its brake just stopped working.
The brake booster was extremely hot. The brake paddle when pressed just hit the floor and the SUV just kept on rolling.
Any reasons/solutions for this?
I was thinking to water cool :cool: the break booster, would that help?
You are braking more than usual . ?
How much time from the last time you change the brake fluid . ? with a DOT aproval one ?
2nd. If there was no hydraulic pressure loss, then you are undoubtedly dealing with old, diluted, dirty, compressible hydraulic fluid, which does no good in a braking system. If this was caused by a great deal of braking in the prior minutes/seconds leading up to the event, then I would also highly recommend you change and flush the fluid in favor of some new, DOT approved fluid.
I use Seiken DOT 3 brake fluid. Last time I changed was I guess two years ago.
http://www.seiken.com/english/chemical/bf.htm
As for breaking usage, I use them to avoid hazard. Not that I like 'braking'.
Pressure loss: well the brake paddle just did not work and the paddle just went 'in' and hit the floor giving the feeling as if there is no pressure.
Its working fine now. But I am not trusting this SUV on a hilly track, for now.
Furthermore, can I use DOT 4 in the existing system?
And what about DOT 5 ?
Sounds like a bad master cylinder to me. Either that or boiling brake fluid.
Oh yeah the master cylinder was really hot.
Should I just change the Master cylinder? And I am going to go from DOT3 to DOT4 today, do I need some special flushing methods or does that not really matter?
Depending on how much water is already in your brake fluid you might have to bleed it a few times more after you get it hot. Water substance tends to look kind of waxxy. So fresh fluid will boil some of it out slowly, hence repeat bleeding.
(or at least I had to do it on a '94 993, drove me NUTS.)
I'm thinking in that also .. just bleed it several times until you get clean fluid, test ride and heck it again ..
I wouldn't do any modifications, what you need to do is fix the problem and get it working like it should. Fluid flush/bleed is a good place to start.
Ok almost same problem. On the 'hilly area’, I could feel a little power loss in brake. I had to stop the vehicle so that master cylinder could cool down a bit.
It was definitely better than before. Master Cylinder was not that hot as it was before (the old one).
Sounds like standard brake fade to me. What pads did you use?
