Have diff. leak-need help
Houston
I am a bit of a noob and have never cracked a differential. My rear diff is leaking and it looks like it is coming from the front of the diff. Is this most likely the pinion seal? Can you help me identify which part it is in this SOR diagram? Is it simply 41?
Thanks!!
41 is the rear cover gasket. That's another common source for rear diff leaks. But if coming from the front of the rear diff, it could be the pinion seal but to be sure:
1. Remove the drive line and inspect the area surrounding the pinoin nut. A common place for a diff leak is the splines between the pinion and the flange. If the problem is here, you might as well replace the seal too since you will have to remove the nut and the flange.
2. Once removed, inspect the flange for wear. Using a worn flange with a new seal may be a temp fix but it may soon leak again.
3. Use good silicon or other sealer on the inside of the flange splines before re-assembly to prevent the leak through the spline area.
4. If your pinon nut is a stake type, use a new nut. If it is a cotter key type, splurge for a new cotter key.
5. Don't forget to torque the pinon nut to specs.
Oh yea, you might want to drain the diff before doing this.
I replaced the pinion seal on my rear, torqued it back down to spec and about 1000 miles later the pinion (not the nut) had come loose and shortly after that it failed.
A little bit ago it dawned on me that once I loosened that nut up I basically screwed the preload setting and even though I retightened it to spec that's what caused it to fail shortly after.
Soooooooo.... Whaddya guys think.
Is it advised to just do that seal or is it necessary to reset the preload and shims and all that at the same time? Not sure but just wanted to bring it to mind, and see what the experts say.
No, you probably didn't stake the nut well enough and it worked its way loose...
I've replaced probably 10 pinion seals with an impact and the "feel" approach and the only one to have problems was on my truck when the nut was not a stake nut. (dire circumstances)
HawkDriver,
Did you dig in and check your shims?
I replaced my seal on one and impacted my nut back on (ouch!) and gave it a test spin - not good.
So the next third I got I took a peek at the shims - read more here:
https://forum.ih8mud.com/showthread.php?t=49036
Should be ok to just re-torque if its not a crush-sleeve type pinion. If its a crush sleeve type, then personally, I would probably drop the third, take out the carrier and do a pinion preload setup on the bench with a new crush sleeve. Then reinstall the carrier and setup backlash and preload on carrier bearings and finally run a pattern before calling it good.
