Hatch latch fun
Lincoln, NE
OK, so I've had the outside hatch handle fail once before on one of my trucks.
No big deal, I've bought the most likely broken part as detailed in this thread:
https://forum.ih8mud.com/80-series-tech/287854-fixed-upper-hatch-outer-latch.html
My local stealership charged me $5.01+tax for it. Their parts markup is impressive.
5 minute fix right?
Wind backwards to yesterday.
So - the :princess: was dropping the kids off at school, the hatch wouldn't open so she had one of the :bounce: climb through and open the hatch from the inside to get a cello out. Then :princess: fixed it by flipping the child lockout switch on the back hatch and closed it. :doh:
Then she let me know it wasn't working. :crybaby:
So - now I get to disassemble the hatch latch from inside the vehicle with the hatch closed and the child disconnect disconnected to see if I can trip the latch to open the door to... :bang:
I wonder if I can slip a shim through the tailgate/hatch and flip the child lockout disconnect and get the interior hatch latch working. Has anyone had to try this?
Fun times.
Subscribed for two reasons: my rear hatch handle occasionally binds up and I cannot unlock the hatch and open it, and I do not have any child lockout switch on the rear hatch. Is this a feature added later?
This wasn't so bad. The part number 69293-12040 was correct and a 100% replacement fit for the broken one. I think this wears out by the metal bracket that it feeds into gradually cutting off one of the tabs over time & use.
Getting the hatch open was easier than I had feared. The rear hatch handle has two screws in it. From inside the back of the truck, remove those two screws, pull the facing plate off of the latch handle. Inside there is a horizontal rod - grab hold of it and push it left. Click. Push the hatch open. Work upside down outside the truck from there.
To replace the plastic bit you'll need to unsnap the interior cover. The plastic clip goes into the hole in a metal plate THEN the connecting rod goes through the plastic and while holding it in place you have to push the tab over the connecting arm - it all makes sense when you look at it.
Thanks for the he tip guys! I just bought 69293-12040 from the dealer and it fixed the exact same issue for me. Glad it was only a $4 fix!!!
Does turning the key in the hatch lock not also release the hatch latch?
Not on mine. '97 PPH
BTW on mine the return spring for the liftgate portion of the hatch handle never pushes the handle out so I always have to remember to push it manually or it won't latch closed.
Also I can only lock/unlock the hatch with the key. Do the same model RC car motors that fit the door locks fix the lock actuators in the rear?
