The only family member I have that uses the back seat has no thumbs so the grab handles are wasted on her
I think that you may be on to something, especially with that last point. The last time I tore down our 62, I almost deleted the said fan... but chose to re-install it in the end as it does actually come on from time to time. The heat in the engine bay gets pretty intense, especially in the summer.Having a poverty package '88 and having had a 1990 FJ62 previously, I've often wondered if Toyota just made the 62 to use up parts from the 60 production line and to maybe test some newer technology like electric windows, locks and antenna before putting it all in the 80 series. Probably not the case, but I can't help wondering every time I look at the carb cooling fan!
Keep in mind the 3FE FJ80 trucks also had a cooling fan for the EFI, but completely different than the 60/62 fan. So they went through the trouble of designing a new fan for the 80 series. The way I like to look at it, is that generally speaking, automakers are not in the business of doing things for no reason, or giving things away for "free". If the fan wasn't necessary, they wouldn't have put it.I think that you may be on to something, especially with that last point. The last time I tore down our 62, I almost deleted the said fan... but chose to re-install it in the end as it does actually come on from time to time. The heat in the engine bay gets pretty intense, especially in the summer.
Those are very good points. In the end, the reasons that you noted are why I left the cooling fan in place. If the engineers felt it was necessary for proper cooling, it didn't seem wise to delete it. In summer temps, the fan comes on nearly every time I turn the old girl off.Keep in mind the 3FE FJ80 trucks also had a cooling fan for the EFI, but completely different than the 60/62 fan. So they went through the trouble of designing a new fan for the 80 series. The way I like to look at it, is that generally speaking, automakers are not in the business of doing things for no reason, or giving things away for "free". If the fan wasn't necessary, they wouldn't have put it.
Inline 6 engines that had the exhaust and intake on the same side almost always had issues with exhaust heat causing issues with the fuel system. Carb and EFI ones. Nissan EFI I6's had cooling fans. The first few years of the Ford 300-6 EFI engine had an injection cooling fan before switching to heat-shielding and higher fuel pressure (60 PSI, vs 40 PSI that every other Ford of the time used). The Jeep 4.0 I6 infamously had tons of heat related issues with its fuel injection system, with Chrysler adding more and more heat shielding over the years, to the point where they had individual heat shields for specific injectors.
Interesting! I wonder if it was truly never available in the U.S., or if it was just a specific request a dealer had to make, and no dealers did it?Interestingly, I've had two Canadian market FJ62s (an '88 and an '89) and both were equipped with headlight washers. Aside from the speedo being in km/h, they seem to be otherwise identical to the US-spec FJ62s.
The FJ62, in non-US markets came out in late 1985 if I remember correctly (so pre face-lift). With the 1987 face-lift (round to square headlights etc), many components changed, but they were still FJ62s. So no, the FJ62 was not a parts bin special.Having a poverty package '88 and having had a 1990 FJ62 previously, I've often wondered if Toyota just made the 62 to use up parts from the 60 production line and to maybe test some newer technology like electric windows, locks and antenna before putting it all in the 80 series. Probably not the case, but I can't help wondering every time I look at the carb cooling fan!
It seems like really the only thing that defines the FJ62 vs the FJ60 is the 62 having a 3F engine. As you mentioned, there were some round-headlight old-interior FJ62s made. I think the Japanese market also got the refresh front end and interior before the rest of the world, as well.The FJ62, in non-US markets came out in late 1985 if I remember correctly (so pre face-lift). With the 1987 face-lift (round to square headlights etc), many components changed, but they were still FJ62s. So no, the FJ62 was not a parts bin special.
The engine is precisely what differentiates an FJ62 from an FJ60. Same with an HJ61 vs an HJ60. Americans get hung up on the headlight shape because it happened for them at the same time and is more visually obvious, but it is irrelevant. For example, there were square headlight HJ60s made until the last year of Japanese production and round headlight HJ60s rolling off the production line from Day One. Same for the BJ60, though after 1987 they were only sold in a few countries.It seems like really the only thing that defines the FJ62 vs the FJ60 is the 62 having a 3F engine. As you mentioned, there were some round-headlight old-interior FJ62s made. I think the Japanese market also got the refresh front end and interior before the rest of the world, as well.
