Has anyone used this crossmember? Advance Adapters but NOT the propeller style.
Los Angeles
I searched long and hard but didn't find anything. Has anyone used the crossmember below? It attaches to AA's adapter between the trans and T case. I have that adapter (NV4500/Orion behind SBC). Is that sufficient to support everything or do I need an additional crossmember for the T case? @orangefj45 , Georg, what do you recommend? By the way, trans and case arrived safely and look great! I'll give you a call later this week for a walk through.
AA crossmember
I don't have that crossmember in my setup; SBC, NV4500, 3 SPD transfer case. Adapter kit for conversion was Downey kit with rear support on the transfer case. I do remember reading a thread where Downey advised against multiple mounts. In other words, use a transfer case mount or a transmission mount but not both. In that vein, use the mount that attaches to the AA adapter and you should be good to go.
Talk to Georg, hanging a cast iron Orion off an aluminum adapter , not my 1st choice.
It's done all the time. I think AA and Novak only makes Aluminum adapters. Some GM bellhousings were aluminum.
^^^^^^^THIS^^^^^^
I'm not familiar with the AA crossmember that's linked, but I seen folks make something similar. Use one crossmember, either one or the other, but not both. There's no way to evenly support the driveline with multiple crossmembers. I run a SBC, SM420 and a Dana 20 tcase. My cross member is under the aluminum adapter between the trans and tcase.
Believe the reason for not using both is to account for frame flex on hard off road wheeling.
Believe unless I'm mistaken the AA aluminium adapters do not hang vertical but bolt on the bottom to a steel crossmember. 8/80 Toyota decided a crossmember motor was better than a vertical mount to the bellhousing. BJ4X always used a crossmember. Vertical mount bolt have support the weight as well as torque. Bottom mount just the torque. Remove the bolts and both styles and see what happens.
The only thing I like about it is (if I am correct) it seems to take some of the rotational torque off the back of the aluminum t-case.
That's what i was thinking. It mounts to the adapter between the trans and T-case which has this provision machined into it already with a GM style trans mount, so nothing is attached to the t-case itself, unlike the old propeller style.
AA crossmember
I used this crossmember when I did my V8 conversion over 15 years ago. I am using it to support my 700R4 trans. Have not had any issues what so ever with it. I have had to pull the trans twice (for a front seal and trans pump repair) and this mount makes it easy to support the trans while installing. If I remember the only other thing I had to do was to cut out and relocate back the round structural tube mounted between the frames for additional clearance.
Thank you!!
